priming a turbo?
Old Nov 25, 2007 | 04:52 AM
T9U4ReBgO's Avatar
Default priming a turbo?
ok I'm standing here freezing my *** off trying to finish this turbo install on my EF sedan...I had a never used sc34 so do I need to prime oil through it if so how and is it necessary before I hook the oil feed line up?.....thanks guys
Old Nov 25, 2007 | 04:58 AM
NJIN BUILDR's Avatar
Default Re: priming a turbo? (T9U4ReBgO)
It's not a bad idea to give it a little squirt of engine oil into the oil inlet.But your turbo will get plenty of oil on start up.The turbo will not have any load on it until boost.At idle it will hardly be turning if at all.
Old Nov 25, 2007 | 05:18 AM
T9U4ReBgO's Avatar
Default Re: priming a turbo? (NJIN BUILDR)
so it will be fine to just hook everything up and start it up and let idle to get oil circulating?
Old Nov 25, 2007 | 05:33 AM
Yup
Old Nov 25, 2007 | 05:37 AM
turbodano's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by T9U4ReBgO &raquo;</TD></TR><TR><TD CLASS="quote">so it will be fine to just hook everything up and start it up and let idle to get oil circulating?</TD></TR></TABLE>
When the car starts don't start reving it right away but at the same time don't let the car keep stalling out. Alot of people kill their turbos from stalling out during the tuning process.
good luck with your set up.
Old Nov 25, 2007 | 05:49 AM
T9U4ReBgO's Avatar
Default Re: priming a turbo? (turbodano)
ok guys thanks for the help imma go back to freezing my *** off and finish her up!!!
Old Nov 25, 2007 | 08:17 AM
shortyz21's Avatar
i always get someone to hold the oil line with it off and turn the engine over before i hook it up to the turbo..
mainly to flush any **** outta the lines u just put in, and make sure u actually have oil.
u dont want a piece of teflon or hondabond going into your turbo..
Old Nov 25, 2007 | 08:20 AM
95dxsir2's Avatar
lol , ok, have fun. when i do my install, I'll put some oil in the inlet port. Just to make my conscience feel better (since it's brand new anyway).
Modified by 95dxsir2 at 9:34 AM 11/25/2007
turbodano's Avatar
Default Re: priming a turbo? (shortyz21)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by shortyz21 &raquo;</TD></TR><TR><TD CLASS="quote">i always get someone to hold the oil line with it off and turn the engine over before i hook it up to the turbo..
u dont want a piece of teflon or hondabond going into your turbo.. </TD></TR></TABLE>
Not a bad idea but make sure you hold the compressor wheel so the wheel and shaft don't rotate. Don't worry it will not take your fingers off as long as you don't grab it while the car is running.
Old Nov 26, 2007 | 03:55 PM
shortyz21's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbodano &raquo;</TD></TR><TR><TD CLASS="quote">
Not a bad idea but make sure you hold the compressor wheel so the wheel and shaft don't rotate. Don't worry it will not take your fingers off as long as you don't grab it while the car is running. </TD></TR></TABLE>
i take the plug wires off and just turn the motor over with the starter..
Old Nov 26, 2007 | 04:48 PM
95dc2teg's Avatar
i take the plug wires off and just turn the motor over with the starter..</TD></TR></TABLE>
thats what i do.
youryanyou
Feb 27, 2011 03:06 PM
SpoolnByYou
Feb 14, 2006 05:31 PM
Firstoost
Oct 15, 2005 05:23 PM
goofball123321
Oct 9, 2003 09:52 PM
2000vsm
Sep 1, 2003 04:36 AM
