Precission Intercooler inlet and outlet size?
Old Apr 13, 2004 | 04:27 PM
B18 CYA's Avatar
Default Precission Intercooler inlet and outlet size?
For the Precision 600 HP 31.5 X 8.0 X 3.5 intercooler, anyone know the size for the inlet and outlet or whatever you call it...endtank or what not... need to buy some intercooler piping. Thanks
Old Apr 13, 2004 | 05:01 PM
Ben Huynh's Avatar
Default Re: Precission Intercooler inlet and outlet size? (c2nap)
Both are 2.5".
Old Apr 13, 2004 | 05:05 PM
93LSivic's Avatar
Actually if it is p/n AS-1025 then it has 2.75" in/out. I have my dealer catalog right here in front of me.
Old Apr 13, 2004 | 05:07 PM
Ben Huynh's Avatar
Default Re: Precission Intercooler inlet and outlet size? (93LSivic)
It's 2.5" ID and 2.75" OD.
Old Apr 13, 2004 | 05:09 PM
93LSivic's Avatar
Default Re: Precission Intercooler inlet and outlet size? (ben@importparts.com)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ben@importparts.com &raquo;</TD></TR><TR><TD CLASS="quote">It's 2.5" ID and 2.75" OD.</TD></TR></TABLE>
That makes sense since the endtanks are cast. You would want to order 2.5" piping for that IC.
Old Apr 13, 2004 | 05:35 PM
B18 CYA's Avatar
So I need 2.5" for one side and 2.75" for the other?
Old Apr 13, 2004 | 09:39 PM
Sleepin''s Avatar
Default Re: (c2nap)
Nope, just 2.5" piping, and if you want to get it perfect you will want 2.75" to 2.5" silicone reducers to go from the intercooler to the piping. What those guys are saying is that the Inside Diameter of both the intercooler inlets & outlets are 2.5", but because the casting is so thick the Outer Diameter of both the inlets and outlets are 2.75"
Old Apr 13, 2004 | 10:28 PM
TURBODC4TEG's Avatar
Default Re: (Sleepin')
or u could get the end of your ic piping flared out to 2.5
Old Apr 13, 2004 | 11:59 PM
ndogg's Avatar
just get 2.5"ID silicone connectors. they will be a little tight but they work fine. no need for the 2.75 - 2.5 transition.
Old Apr 14, 2004 | 06:08 AM
NapTownSi's Avatar
Default Re: (ndogg)
I run DRAG IC piping and bought one 2.75-2.25" silicone reducer for the compressor side and one 2.75-2.5" for the charge side from ATP. DRAG's piping is 2.5" for the charge pipe and 2.25" for the condenser pipe. They fit perfectly and I would highly recommend you do this if you have this piping.
-Mark
Rodzknight
Feb 14, 2008 08:42 AM
turboedc2
Jun 23, 2005 06:58 PM
dornon13
Aug 11, 2004 09:37 PM
ghettochild
Aug 10, 2004 07:02 PM
B20LS-T
May 9, 2002 11:06 PM
