precision sc61
Old Feb 23, 2003 | 10:40 PM
gsrt's Avatar
Default precision sc61
anyone use sc61 for daily driving and track use!!! when does it get full boost for 1.9 gsr?
Old Feb 26, 2003 | 08:14 AM
Armaan's Avatar
Default Re: precision sc61 (gsrt)
Good question. Anyone?
Old Feb 26, 2003 | 08:16 AM
b18bturbo's Avatar
Default Re: precision sc61 (2.0L Turbo)
4800 rpm spool on a 2.0 liter 1.98 acutally but close enough.
Old Feb 26, 2003 | 08:25 AM
DIRep972's Avatar
Smarter than you
Default Re: precision sc61 (b18bturbo)
when did u test this? and it hit how much boost at 4800rpm? 6psi? 15psi? 30psi?
Old Feb 26, 2003 | 09:46 AM
MotorMatrix.com's Avatar
I am a bad person
Default Re: precision sc61 (DIRep)
I doubt youll see full boost by 4800rpm on the staright t4 sc61 with .68 rear and t04s front housing. Only way I see that happening is with a .48 rear and t04e front housing maybe.
Old Feb 26, 2003 | 10:05 AM
b18bturbo's Avatar
2psi at 4800rpm full bost on 2.0 liter not exactly your pocket rocket. This is on 95 GSR 2.0 liter
This is on sc6169 it t3 exhaust housing not the huge t4 housing
[Modified by b18bturbo, 1:06 PM 2/26/2003]
Old Feb 26, 2003 | 11:45 AM
rOby's Avatar
i got the t4 housing :D
Old Feb 26, 2003 | 11:46 AM
Greaser's Avatar
Default Re: precision sc61 (rOby)
i just bought one and it was labled the PT61 for being a T4 turbine and housing. i was speaking with harry at PT. i think in the above posts the 1.98 was for Pressure Ratio or Bar....but since it wasnt clarified. Or maybe a 1.9 litter GSR motor meaning sleeves and 83mm pistons.....hmm
haha i think a turbine and housing sized up so big that you dont use a wastegate would hit 2psi by 4800.
[Modified by Greaser, 8:51 PM 2/26/2003]
[Modified by Greaser, 8:52 PM 2/26/2003]
Old Feb 26, 2003 | 11:49 AM
Full-Race Javier's Avatar
Default Re: precision sc61 (Greaser)
mine's on the way too
Old Feb 26, 2003 | 11:54 AM
Greaser's Avatar
Default Re: precision sc61 (javierb14)
pm me your number so i can contact you. i wanna hear the way the turbo responds or tell how it responds whoever gets it running first.
which one did you get?...i got the 56trim 82mm with T04s housing/ T4 76trim turbine in a .58 housing. I think its gonna blow away my 50trim that i realized i was wrong about.
Old Feb 26, 2003 | 02:05 PM
djdxm's Avatar
I am just about to order the same turbo, are you running it? I am hoping that it will be enough to support around 600whp... Are you happy with what you got?
Old Feb 26, 2003 | 02:15 PM
Greaser's Avatar
Default Re: precision sc61 (djdxm)
I havent got it yet. It will be at least a month or two before i can report on its capabilities, watch for other people that have recently bought it as well.
It will replace a GT3037s which is a GT37compressor 52 trim 76mm. This is very close to this 56 82 mm compressor the SC/PT 61 comes with. That 52 trim was the BOMB on a mildly built 2.0 liter. so i'm sure the new turbo will be just as good or better. i did a T4 side cuz i really dont care at all about spool up.
Old Feb 26, 2003 | 02:30 PM
T04S housing for more volume and T3 for the street. i wont have the car running for a while.....the motor is even broken in yet. im probably going to play around with the exhaust housings when i get everything working the way i want it.
Old Feb 26, 2003 | 02:34 PM
djdxm's Avatar
I agree. not caring that much about spoolup. I want to hit my HP goal. Plus you can aways fix the spool with some nos... or alot of nos
Old Feb 26, 2003 | 03:31 PM
Arturbo's Avatar
Better than steak
25 Year Member
Greaser, There is a sc51 going on a SR20DET up in NJ that I sold a turbo too. Im sure Geoff can tell you more about it since they are good friends. Javier, your turbo should be here soon.
art
Old Feb 26, 2003 | 03:48 PM
Greaser's Avatar
Default Re: precision sc61 (Arturbo)
do tell then, i know a couple heads up in NJ and hope to see some fellow SR competition when i head up for some of this years events.
Old Mar 13, 2003 | 09:54 AM
hybrid901's Avatar
I just received mine from Art today and teh best part was it only took 2 days to get. If I get time I will install it today and go to the track tonight but probably won't have time until this evening to install. Its a beautiful turbo.
Old Mar 13, 2003 | 02:34 PM
dragnGSR's Avatar
Default Re: precision sc61 (hybrid901)
Hey man, keep us updated. Paul
Old Mar 13, 2003 | 02:43 PM
hybrid901's Avatar
Default Re: precision sc61 (dragnGSR)
I won't be taking it to the track tonight, haven't even been able to start on it yet.
Old Mar 17, 2003 | 09:46 PM
hybrid901's Avatar
Screw Art and Precision. I installed my new sc61 and spun a rod bearing the next day. Its all there fault. LOL I better quit joking I've seen how people take things around here.
I love the turbo. It spool exactly like my 60-1hifi did and obviously flow more air. I have been running 15-20psi for the past 4-5 mos with the hifi and when I installed the sc61 I turned the boost down to 14psi. My techedge was showing .4-.5 leaner everywhere. I went out to the street races and kept it on low boost until on the way home and got in a little race and without even thinking I hit high boost and make a few 3,4,5 gear pulls and it was flowing a little to much air for my 550's and 93 octane. on me. I pulled the oil pan yesterday and I beat the rod bearing out on cylinder #1. I will be pulling the motor Wednesday, installing another crank, bearings, and rings. I need something to play with until I finish my sleeved block.
[Modified by hybrid901, 6:47 AM 3/18/2003]
Old Mar 18, 2003 | 06:43 AM
QCKGSR's Avatar
Old Mar 18, 2003 | 06:46 AM
b18cTurbo's Avatar
is your sc 61 exaust side a T3 ?
Old Mar 18, 2003 | 07:13 AM
hybrid901's Avatar
Default Re: precision sc61 (C5turbo)
its a .63 with a stage 5 wheel
Old Mar 18, 2003 | 08:50 AM
Full-Race Geoff's Avatar
Old Mar 18, 2003 | 08:55 AM
I am a bad person
Default Re: precision sc61 (FFgeoff)
Weird??? I'm getting email notifcations that say one thing then i come in here and cant find the post!!! anyone esle notice this?? the poster was "ffgeon" not ffgeoff!!!
30psi_gst
Jan 25, 2011 10:58 AM
BOOSTEDCIVICD16
Jan 29, 2004 04:40 PM
BoosterChair
Apr 13, 2003 09:18 PM
Stock@$$GSR
May 24, 2002 02:54 PM
