Precision SC34 .48 or .63? Maybe even a completely different model?
Old Feb 9, 2005 | 07:31 PM
DigitalFusion's Avatar
Default Precision SC34 .48 or .63? Maybe even a completely different model?
Hey All,
I have spent the last few days searching the forums, both recent posts and the archives. I have also all over the 'net looking at dyno graphs and info. I am looking to purchase a new turbo to replace my blown lil T3 from the SVO (.48 hot/.60 cold/60 trim). I really liked the way this turbo spooled so fast, but I did not like the way it ran outta breath on the top end. I dont drag race or street race so I am not looking for some SC61 using 500+ hp monster. The only thing I want is a very streetable car with a turbo that will spool nice and fast, but still have the ability to grow with me if I build the bottom end. A friend of mine recently purchased a Mitsu EVO, and I would like to eventually get my car to be able to hang with him, even if he does some mods.
Having said that, I think I have narrowed my choice down to the SC34 but I am still open to suggestions. The one thing I am not sure of is choosing the .48 or the .63 housing. I know with my current turbo, I wished I woulda kept the .63 hot side instead of selling it and going with the .48 With this bigger SC34, I dont know if I would have the same regret since it flows more CFM.
Here is my current setup:
Engine/Transmission
- B16A3 Engine
- GSR Transmission
- ACT 6 Puck Clutch
- Xtreme Pressure Plate
- 11lb Lightened OEM Flywheel
- 2.5" Aluminum Radiator
Turbo
- RevHard Cast Mani
- Spoolin Performance 3" Downpipe
- Thermal 2.2" Exhaust (soon to be Kteller 3" & magnaflow muffler)
- T3 63/48/60 Trim Turbo
- 29x8x2.75 Custom IC
- Tial 35mm WG (10.2 PSI Spring)
- 2.25" Charge Piping
- TurboXS RFL BOV
- RC 550cc Injectors
- Walbro 255lph HP Fuel Pump
- Crome UNTuned Chiped P30 w/Datalogging
What do you guys think I should go with? The SC34 with teh .48, or will I want the .63... or maybe even a completely different turbo?
Old Feb 9, 2005 | 07:50 PM
Tchleung's Avatar
well. when did you start to build boost(1psi) and reach full bosot by(what psi) on your b16? I have a SC34 with .63 on my stock b16 and can tell you if the upgrade is too much lag for you..
Old Feb 9, 2005 | 08:00 PM
Default Re: (Tchleung)
I started boosting at about 3500 and had full boost (10 PSI) by about 4200
Old Feb 9, 2005 | 08:12 PM
Tchleung's Avatar
well on my SC34 with .63, 1psi at 3,500RPM, little bit earlier in 5th gear. and 10psi at 5000rpm. some ppl ahve reache full bosot in the mid 4000's tho. Miesn might be higher due to some leaks.. whcih I seem to always find little ones everywhere... Hope that gives you insight.
Old Feb 9, 2005 | 08:16 PM
have u dyno'ed ur setup at all?
Old Feb 9, 2005 | 08:20 PM
Tchleung's Avatar
Not yet. hopnig to in spring. All I know is it's fast. then aagain. fast on HT = 500+WHP lol
Old Feb 9, 2005 | 08:45 PM
turbo*s2k's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tchleung &raquo;</TD></TR><TR><TD CLASS="quote">Not yet. hopnig to in spring. All I know is it's fast. then aagain. fast on HT = 500+WHP lol</TD></TR></TABLE>+
LOL!
Old Feb 9, 2005 | 08:48 PM
Tchleung's Avatar
Default Re: (TurboChrgd_Civic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TurboChrgd_Civic &raquo;</TD></TR><TR><TD CLASS="quote">+
LOL!</TD></TR></TABLE>
Yeah that's right you. You are almost there damn guy hahaha
Old Feb 9, 2005 | 08:52 PM
turbo*s2k's Avatar
Yeah that's right you. You are almost there damn guy hahaha</TD></TR></TABLE>
I'm working on it!
I have to upgrade my turbo again...
Old Feb 9, 2005 | 08:58 PM
what is the rest of ur setup?
Old Feb 9, 2005 | 09:05 PM
turbo*s2k's Avatar
Default Re: (DigitalFusion)
current setup:
2000 Civic Si
B16a2
GE Sleeves
Eagel rods
Arias pistons (9.5.1 compression)
Type R head (stock intake/exhaust valves) RM springs/retainers
RevHard Intake manfold
JG 65mm throttle body
Full-Race manifold
Full-Race t3/t67 (stage 3 exhaust wheel .62 a/r)
PWR Intercooler 24x8x3
Blitz BOV (hard spring)
Tial 44mm wastegate
3" downpipe, 3" test pipe
Thermal exhaust
B16 tranny Quaife LSD
ACT Extreme pressure plate
ACT 6 puck
ACT lightened flywheel
Hondata S100B
Rodchestor 1000cc injectors
Walbro 255 lph (high pressure)
AEM fuel rail
Fast-turbo complete fuel line kit
Aeromotive FPR
and some other stuff..., etc.
I just got my head back from portflow, and picked up some type r cams so I should be pretty close to 500hp after I tune it again. I might go ahead and go bigger on the turbo at the sametime. Still deciding between a gt35r t04s & t3/t67 ptrim wheel.
Good luck with your setup!
Old Feb 9, 2005 | 09:10 PM
how about ur setup Tchleung?
Old Feb 9, 2005 | 09:15 PM
Tchleung's Avatar
JDM B16A motor swap
JDM J1 transmission
97 Acura Integra Type R intake manifold
96 Acura Integra GSR throttle body
Hondata intake manifold gasket
B&M fuel pressure regulator
B&M fuel pressure gauge
Walbro 255LPH HP fuel pump
Clutch Masters clutch and pressure plate
450CC peak and hold injectors
CRFAB turbo manifold
Precision SC34 turbo
2.5" Down pipe
2.5" Stainless steel mandrel bent exhaust
14” Magnaflow resonator
Tial wastegate
2.5" Stainless steel charge pipes
Spearco Intercooler
Chipped ECU
Greddy Type S blow off valve
PWR rad
Full-Race traction bar
ARP headstuds
Like I said. Stock b16(internals)
Old Feb 10, 2005 | 02:18 PM
Old Feb 10, 2005 | 05:32 PM
Tchleung's Avatar
GT28RS with .63 or even the .82 AR turbine
Old Feb 10, 2005 | 06:45 PM
DefiantGSR's Avatar
TurboChrgd_Civic, what's your displacement?
Old Feb 11, 2005 | 10:40 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tchleung &raquo;</TD></TR><TR><TD CLASS="quote">GT28RS with .63 or even the .82 AR turbine</TD></TR></TABLE>
thats outta my price range big time~!
Old Feb 11, 2005 | 12:14 PM
Tchleung's Avatar
Haha I know me too. if I had the money myself I'd go with taht but nooo lol. Stick with the SC34 .63.. you'll like it. It has great top end still
Old Feb 11, 2005 | 12:40 PM
yeah, im pretty sure that is what I will go with, it doesnt seem like there is all that big of spool times between the 63 and the 48
Old Feb 12, 2005 | 04:52 PM
Tchleung's Avatar
Freakin great.. my 7000Km SC34 is shot... went to install the new manifodle tc today only to see oil everywhere.... Omg so pisssed..
Tchleung's Avatar
I dunno what turbo tog et now. I don't really wanna get SC34 again as I've already done taht. I want to go BB but Ionno...
Old Feb 12, 2005 | 06:04 PM
Tchleung's Avatar
Currently I run the SC34:
Compressor:
.60 A/R
57 Trim
Turbine:
.63AR
Stage 2
But after looknig around. I might stick with an SC34 but go witht he larger one with the stage 3 for even more top end at the expense of another few 100 rpm spool time....
r1paniccia
Aug 21, 2012 05:55 PM
BLWNB16A@11psi
Aug 26, 2009 10:08 AM
EdsGTI
Apr 25, 2006 02:30 PM
mrbsponge
Sep 29, 2004 06:11 PM
