precision sc 61
Old Apr 28, 2003 | 08:34 AM
  #51
KCHybrid's Avatar
Default Re: precision sc 61 (MotorMatrix.com)
Are these turbos water cooled? I looked at the Precision site and didnt see an answer. (granted I just took a quick glance at it)
Old Apr 28, 2003 | 09:46 AM
  #52
Dublocivic's Avatar
Default Re: precision sc 61 (KCHybrid)
The sc61 is oil cooled.
Old Apr 28, 2003 | 10:44 AM
  #53
KCHybrid's Avatar
Default Re: precision sc 61 (Dublocivic)
is there any way to get one water cooled?
Sorry for what may be seen as a hijack, just trying to find the turbo I need and would like to have.
Old Apr 28, 2003 | 12:26 PM
  #54
t04s's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KCHybrid &raquo;</TD></TR><TR><TD CLASS="quote">is there any way to get one water cooled? </TD></TR></TABLE>
Why?
Old Apr 28, 2003 | 12:32 PM
  #55
KCHybrid's Avatar
Default Re: precision sc 61 (t04s)
Better cooling less ferquent oil changes (not that I wouldnt step up oil changes once I am boosted). I supose you could say extra insurance for longer turbo life. Better cooling more efficent.
Old Apr 28, 2003 | 01:03 PM
  #56
bcause's Avatar
Banned
what is the spooling time difference compared to my t3|t04E? I'm about to buy another turbo for my b16a..I want more power but since a b16a has no torque, is the lag gonna kill me?
Old Apr 28, 2003 | 04:40 PM
  #57
93LSivic's Avatar
Default Re: (bcause)
Have fun spooling it with 1.6 liters. Im gonna have a hard enough time trying it with 1.8L.
If you want a precision for your setup you should go with the sc44. Talk to Art, he will point you in the right direction.
Dan
Old Apr 28, 2003 | 09:43 PM
  #58
slowsi00's Avatar
Default Re: (93LSivic)
well i was told its would be a good turbo for a b16 spinning high rpms...
with boost around 5k and 8700redline u should be all good
Old Apr 29, 2003 | 02:20 AM
  #59
QCKGSR's Avatar
Default Re: precision sc 61 (IRepD)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IRepD &raquo;</TD></TR><TR><TD CLASS="quote">
SC63 is the new super duper pimp turbo from precision. Actually, its custom and was made specifically for SFP and MotorMatrix has one. They could probably make it for u but this turbo is geared for those who wanna make even more power then the SC61.</TD></TR></TABLE>
i have a sc63 also and it made 315 whp on 9psi just a base map i am going on the dyno today to put more boost to it..... 28 psi and a race motor= BIG NUMBERS
Old Apr 29, 2003 | 02:45 AM
  #60
GOLDBERG's Avatar
Default Re: precision sc 61 (QCKGSR)
keep us posted and can u provide some details of the motor??
Old Apr 29, 2003 | 06:05 AM
  #61
t04s's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KCHybrid &raquo;</TD></TR><TR><TD CLASS="quote">Better cooling less ferquent oil changes (not that I wouldnt step up oil changes once I am boosted). I supose you could say extra insurance for longer turbo life. Better cooling more efficent. </TD></TR></TABLE>
Don't forget you will have to weigh that against running higher colant temps with a water cooled turbo.
Old May 3, 2003 | 09:28 PM
  #62
Armaan's Avatar
Default Re: precision sc 61 (InfamousRS)
Up.
Old May 3, 2003 | 09:51 PM
  #63
ludesleep's Avatar
Default Re: precision sc 61 (2.0L Turbo)
so what makes the to4s different from the rest? I just bought one and really dont know a whole lot about em kinda wondering what i can look forward too
Old May 3, 2003 | 09:52 PM
  #64
Arturbo's Avatar
Better than steak
25 Year Member
Default Re: precision sc 61 (ludesleep)
t04s= 70AR
t04e= 60AR
Old May 3, 2003 | 09:55 PM
  #65
ludesleep's Avatar
Default Re: precision sc 61 (Arturbo)
man so i can expect some hella lag? its on a h series motor with 9.5:1 je
Old May 3, 2003 | 10:06 PM
  #66
Arturbo's Avatar
Better than steak
25 Year Member
Well what turbine wheel do you have?
art
Old May 3, 2003 | 10:20 PM
  #67
ludesleep's Avatar
garret t3 60-1.It has a 4inch compressor inlet and a 2.5 oulet.
Turbine specs:
.82 a/r turbine high flow 76 trim wheel
Compressor specs:
to4s .70 a/r housing w/ 60 trim wheel
Old May 3, 2003 | 10:25 PM
  #68
Arturbo's Avatar
Better than steak
25 Year Member
T31 .76 trim?
T350 .76 trim?
T04 .76 trim (O,P,Q)?
How many blades does the turbine wheel have?
Old May 3, 2003 | 10:33 PM
  #69
Arturbo's Avatar
Better than steak
25 Year Member
Turbine wheel = hot side or exhaust side. Where the downpipe would bolt up to.
Old May 3, 2003 | 10:36 PM
  #70
ludesleep's Avatar
opps it has 11
Old May 3, 2003 | 10:41 PM
  #71
Arturbo's Avatar
Better than steak
25 Year Member
hmm, sounds like you have a:
T31 .82 AR .76 trim(stage 5 wheel)
T04B 60-1 compressor wheel in a 70AR compressor housing.
art
Old May 4, 2003 | 04:52 AM
  #72
Cyber ITR's Avatar
Art i just wondering if i get a t4 housing , can i get the tangential housing ( divided one ) ???
will the tangential housing reduce a noticeable lag compare to a normal high flow housing ?
thanks
Old May 4, 2003 | 05:18 AM
  #73
Arturbo's Avatar
Better than steak
25 Year Member
Default Re: precision sc 61 (SEX DR)
You definatly want the tangential housing, but the divided doesnt make any difference if it is or not. I actually prefer undivided because no one has been able to prove to me divided works better.
art
Old May 4, 2003 | 07:20 AM
  #74
Boost2NA's Avatar
Now im confused on what turbo to get. That sc61 sounds pretty good. damn so many choices
Old May 4, 2003 | 08:34 PM
  #75
MotorMatrix.com's Avatar
I am a bad person
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Arturbo &raquo;</TD></TR><TR><TD CLASS="quote">You definatly want the tangential housing, but the divided doesnt make any difference if it is or not. I actually prefer undivided because no one has been able to prove to me divided works better.
art</TD></TR></TABLE>
I agree. From what i was told the divided is supposed to be for diesel trucks and cars.
