Precision 6262 5-bolt compare to 6262 v-band
I'm wondering how much of different on the spooling time and hp on 6262
(5-bolt and vband) jounry bearing .82ar
I'm looking to make 450hp on a b18c1 with 81.5 turbo piston eagle rod on a stock b16 head with gsr cam on pump gas
As now I got a peakboost ramhorn manifold with a 3" dp with 5-bolt style
Re: Precision 6262 5-bolt compare to 6262 v-band
They only offer the 5 bolt up to a .63 housing so if your wanting to run the .82 you will be required to go vband. But like Mac already said .82 a/r is .82 a/r just different ways the downpipe connects to the housing
Who is Mr Robot?
Turbo is more like total overkill
Like using a flamethrower to kill a fly
A much smaller turbo would make the power you want and have a much better power curve.
1 Post
I'm pretty sure 5 bolt housings flow the worst and do make slightly less power compared to a 4 bolt or vband hotside give the same exact ar size.
Moderator
But when you want A/C and Powersteering AND big turbo, something is going to compromise anyway a bit, so the reduction is negligible. that's why I stated that it didn't really matter in the long run.
For the Evolution, the engine bays were designed from the factory to allow for a lot more than a honda was, and even then, the turbine housing flange system for the 4-9 or even 10 weren't the best flowing for power. But they were much smaller an never meant to do what these 62mm 5 bolt ford styles could, so it doesn't matter at this point as that is an apples to grapes comparison, ya know?
