Precision 5831E oil problem
Hi, As the tittle say, my Precision 5831 keep blowing oil to the exhaust housing after two times repaired and balanced.
First time repaired, I used the B&R .060" restrictor the Shodan recommended. But I believed the seal was already shot but after a second repair, after a few months oil is coming to the EX. housing.
Precision 5831E MFS
-3an feed line
-10an return
80 psi at cold start
Does Precision use a special piston seal (I've using the normal Garrett T3/T4) that my locals speeds shops sale.
https://honda-tech.com/attachment.ph...1&d=1455550696
Precision 5831E MFS
-3an feed line
-10an return
If you're thinking dynamic seal vs. a carbon seal system, then the answer is no. Neither Precision nor Garrett use these for their journal bearing systems, and haven't since the early 1990s. They were originally designed for draw thru carburetor applications as a positive seal to keep oil from being sucked out of the turbo in high vacuum situations. They seal great, but tend to drag on the actual turbine shaft, so, I don't recommend trying to find them to retrofit.
In your case, it may be time to call it a wrap after 2 rebuilds, and use a different company that enables the use of water.
Yeah, I been looking your Hunter turbo for a while and I believe is time to save and bought it.
Q: The T31 .63 a/r ex. housing from the Precision fit the hunter .63 a/r T31 wheel? Or is best buy the whole unit?
deadhero15
May 23, 2017 02:53 AM
xkrazyxjbrkerx75
Jun 24, 2011 04:58 AM
turbo'd integra LS
Aug 31, 2004 07:19 PM
