Pre Dyno Prep?
Old Mar 5, 2006 | 01:43 PM
Quad-Damage's Avatar
Default Pre Dyno Prep?
I'm set to Dyno my car tomorrow, but i changed the oil, with new 10w30 about 350 miles ago and a new OEM Honda filter, i put in 3 step colder plugs about 600 miles ago
Should i just change my oil and keep in the OEM Honda filter, or just change the filter and oil again, even tho it's really low miles on the oil, I also have a oil cooler, so even when i change my oil, it's still very clean. (kinda wastefull such low miles on the oil)
I had a extra set of NGK 3 step colder, already gaped, and my idle is at 20 VAC, so i don't have any boost leaks, I also retightin'ed everything,(bolts turbo/dynopipe exhaust) and I'm going to take the filter off my turbo (at the dyno), anything else i should do, because tools are not a problem, the dyno place has everything I will need, because last time, i had a boost controller problem, but everything is working great now.
Also i might be tuning with C16 gas, (just to see what a stock motor can do) how much 91 oct (ca best pump gas wack) should i have in my car when i dyno with the c16
Old Mar 5, 2006 | 01:57 PM
grubere's Avatar
Default Re: Pre Dyno Prep? (Quad-Damage)
http://www.evans-tuning.com/checklist.html
Also, C16=overkill city.
Old Mar 5, 2006 | 02:23 PM
TurboGSR96's Avatar
It would only make sense to have as little 91 octane in the tank as possible if you were going to add 116, otherwise you are just thinning it out and are not getting the full benefits of the high octane gas, correct me please if I am wrong
Old Mar 5, 2006 | 06:09 PM
Default Re: Pre Dyno Prep? (TurboGSR96)
so about my oil
Old Mar 5, 2006 | 06:11 PM
komat's Avatar
no need to change oil unless you really want to
Old Mar 5, 2006 | 06:24 PM
locash's Avatar
Whats your setup? I have seen VERY few applications that have a need for plugs 3 steps colder.
IntegraType-R
Oct 17, 2008 07:51 AM
xDicktonesx
Feb 23, 2006 10:36 AM
97civicsedan
May 12, 2005 11:08 AM
Pikachu
Apr 11, 2005 06:45 AM
Todd00
14
Jul 16, 2003 05:24 PM
