Power gains?
Old Apr 8, 2016 | 07:33 AM
AcroSilme's Avatar
Default Power gains?
Alright so I have a b20b with everything stock currently but I want to know how much power it would make with these mods
- 1.6 liter Procharger kit for b16 head at 10 psi
- b16 head
- e85 injection
- quality exhaust headers to muffler
- type r b16 cams
- type r valvetrain
- b20b block
- forged internals
- 10:1 compression should be okay on e85 at 10 psi right?
- intercooler for the procharger
Thanks ahead of time.
Old Apr 8, 2016 | 10:00 AM
96ekb20's Avatar
Default Re: Power gains?
honestly if your only going 10psi i dont see why not to run a bit more compression but i also dont know the flow and air out put of that procharger.
Old Apr 8, 2016 | 10:04 AM
AcroSilme's Avatar
I could go more compression but the engine has to be reliable as it's going into my daily so would it still be as reliable or no.
Old Apr 8, 2016 | 02:46 PM
TravisBiggie's Avatar
higher compression won't affect "reliability" if its tuned properly and you're using the correct fuel. 10:5 or 11:1 compression will give you good power on pump gas. if youre running e85, or a higher octane fuel other than pump, you could run even more compression than listed above if you wanted.
Old Apr 8, 2016 | 03:25 PM
Geis's Avatar
It does however, affect the knock limit, which is important to consider when boosting a car.
Old Apr 9, 2016 | 07:26 AM
AcroSilme's Avatar
So on e85 something like 12:1 compression should be okay to run on 10 psi boost
Old Apr 9, 2016 | 01:37 PM
TheShodan's Avatar
Moderator
PSI IS IRRELEVANT. DEPENDS UPON TURBO USED.
Old Apr 9, 2016 | 02:07 PM
2kdrift's Avatar
hes not goin turbo he said procharger
OP:
https://honda-tech.com/forced-induct...chime-2942111/
Old Apr 9, 2016 | 02:39 PM
TheShodan's Avatar
Moderator
OP:
Ok. I'll try this again. . PSI IS IRRELEVANT, IT DEPENDS UPON C-SERIES COMPRESSOR USED.
Old Apr 9, 2016 | 05:53 PM
ls joker's Avatar
Loved
what kind of procharger kit is a start. some chargers may be bigger or smaller.
ATI, kraftwerks,....?
Old Apr 9, 2016 | 08:28 PM
AcroSilme's Avatar
Ati so with the mods listed above about how much power should I make?
Old Apr 9, 2016 | 08:31 PM
DC4KiD's Avatar
Class of 2016.....
Old Apr 9, 2016 | 08:41 PM
AcroSilme's Avatar
Alright dude it seems you can't please everyone
Old Apr 10, 2016 | 02:26 PM
bergercurtis's Avatar
They're trying to indirectly state you're asking the wrong questions.
"How many fish will I catch with this fishing rod versus that rod?" Even then- bad analogy.. Too many factors outside of simply that to even have a clue.
It depends on the compressor efficiency and size of your procharger. You could have a tiny little 20lbs/minute blower or 70lbs/minute. The PSI is irrelevant because until we have the specifics of your setup (more than your 'mods list'), it's a sheer guessing game with no factual base. Further than that, how aggressive of ignition timing? What sized injectors? Etc., etc..
Don't take it personally. People are here to help. It's just a matter of seeing questions like this far too often with focus in the wrong places.
Old Apr 11, 2016 | 09:35 AM
Xanthias's Avatar
Faq section at the top of the FI thread is your friend. There are some very educated people here so dro the ego and learn is what I would say.
Mikes2000civicsi
Jan 22, 2007 12:37 PM
Boostage
Apr 11, 2005 07:11 AM
mR. Vash
Nov 20, 2004 01:58 AM
fro5tbite
Sep 30, 2004 06:36 AM
othick
Apr 2, 2003 04:32 PM
