CSS block question
Old Apr 10, 2016 | 12:39 PM
the_insider's Avatar
Default CSS block question
Are these still seen as a viable alternative to fully sleeved blocks?
Has there been any reported failures?
My goal is under 500hp but will be used on track, and may even compete in a odd race meeting which will be hard on engine for 20 solid mins.
What's the thoughts on these? The idea is still quite new in UK and the info isn't about
Thanks
Old Apr 10, 2016 | 12:50 PM
KevinEF7's Avatar
Default Re: CSS block question
100% still the best option out there
Old Apr 10, 2016 | 01:01 PM
Cabletie's Avatar
I'm intrested in this as well....
Old Apr 10, 2016 | 02:16 PM
bergercurtis's Avatar
Not speaking from experience here, but moreso secondhand anecdotes of sleeving.. I've heard of more problems with aftermarket sleeve systems dropping or moving moreso than CSS failure, but doesn't necessarily mean it's any better/worse.
For 500whp on a B series (only guessing as you didn't specify) should be fine with just a CSS if the block is in good condition, and your tuner keeps everything in check. It would also be a lot cheaper. Good sleeves done correctly though would leave you room to grow power wise. I definitely would imagine aftermarket thicker sleeves will hold up to more.
Old Apr 10, 2016 | 02:23 PM
Turbo-LS's Avatar
Lol misinformation. Sleeves sink from **** poor machine work. If done properly they are by far a superior product BUT the css does work
Old Apr 10, 2016 | 02:31 PM
AZ_CIVIC's Avatar
Locash Racing does Darton Sleeved blocks for $1200 bucks. Good thing about Darton Sleeves is you can replace individual sleeves. Locash Racing also can o-ring and CNC notch blocks for aluminum rods as well.
I currently have a GE 84mm sleeved block that I had bored, honed, bead blasted and o-ringed for $1310 plus $100 dollars for shipping.
So for maybe $500 or $600 bucks more I would much rather have a true sleeved block.
Old Apr 10, 2016 | 02:35 PM
Turbo-LS's Avatar
Agreed plus larger displacement and a better ring seal with the darton sleeves
Old Apr 10, 2016 | 03:06 PM
TravisBiggie's Avatar
or do what I did, and make your own precision block guard, cost me $70 usd. Put it on a level surface unlike me so you don't have to deck it or file down the high spots.
Old Apr 10, 2016 | 03:07 PM
1988dxsedan's Avatar
Agree with all the above. I planned on running CSS, the cost is appealing but until you ship it there and back, at least 100 bucks, you add on boring honing and decking while its there...
325 for css
425 for all machine work
100 min for shipping
850 bucks. It works but for 250-300 more you can get AEBS sleeves or another brand of your choice. I picked up a fresh AEBS sleeved block for 800 shipped.
Css works, its proven for sure. If it was maybe 500 bucks all in ide go for it. IMO if you dont have 300 more dollars to go all the way, maybe a high performance engine build isnt the right path.
-If your about the support on a budget, just get some moroso block filler, that too has been proven to handle power and its truly inexpensive.
Old Apr 10, 2016 | 11:03 PM
The cost of css here in UK is £600 including bore and hone.
Cost of darton sleeves supplied and fitted is £1400
Yes it's for a bseries.
I'm not being cheap, I'm already running forged internals. Acl bearings ect
And power is currently under 400.
My concern is when I put more power through it. The life of the sleeves will be compromised.
I'm not planning on running huge power, as it will be unusable for track. But I will be using this solely on track and it will be getting driven hard for a period of time.
Are darton sleeves worth more than double for my goals?
Old Apr 10, 2016 | 11:20 PM
Cabletie's Avatar
I'm from Italy, and I was searching for a css installer in Europe. I found the one you are saying in the UK, but is cost the double.... 600£ are 847.83 $. That's crazy in my opinion! I'm trying to contact the US Company directly but without success...
Old Apr 11, 2016 | 04:46 AM
TheShodan's Avatar
Moderator
You really won't. See, the CSS process with the original installer is what makes this setup so unique. The fact that there even is an installer in the U.K. is a miracle, so, despite the cost, you have very little option. Get to him if you want this process done, and don't wait for the U.S. one. (Though in either case, if tuning is spot on, you won't need it anyway)
Old Apr 11, 2016 | 05:46 AM
AZ_CIVIC's Avatar
Yes, double is only about $600 or so. Most people always end up wanting more power anyway. If it were thousands of dollars more I can see someone wanting a cheaper alternative but it truly is not that much more.
Old Apr 11, 2016 | 05:56 AM
In the UK, the price difference between the 2 is the equivalent to $1000
UK is so overpriced for everything. We have little choice but to have to pay these prices. Or trust and wait for a place in the US to send one over.
Old Apr 11, 2016 | 06:51 AM
Cabletie's Avatar
I see your point, but the dealer in the UK send the engine to the US..... This is why I'm surprised by the price... why I cannot go direct? They do not answer to my email... hope they are busy at hondadays...
Old Apr 11, 2016 | 07:01 AM
TheShodan's Avatar
Moderator
He's busy when "He's busy". He's not worried about Honda Days or any of these other events. He's an engine builder and machinist, not much of a promotional guy. He's used to phone calls more than e-mails. A man of the 80s.
Call him.. Yes, even if it's international.
Old Apr 11, 2016 | 09:33 AM
AZ_CIVIC's Avatar
Contact Joe at Locash CNC, they do all sleeving in house, o-ring, notch blocks for aluminum rods if wanted.
They can sell you a block or you can send yours and they will sleeve it.
Old Apr 11, 2016 | 11:33 AM
TheShodan's Avatar
Moderator
^^^ An even better idea
Old Apr 11, 2016 | 11:58 AM
Even from UK?
Old Apr 11, 2016 | 12:08 PM
AZ_CIVIC's Avatar
Even from UK?
Of course, I just contacted Joe and he said he just finished sleeving a block and sent it out to a guy in Greece.
He said give him a call and he can answer whatever questions you have.
Below is his website and his number is 602-763-5189.
Engine Block Sleeving : Locash Racing, LLC!, Honda Performance Parts, Dynapack Dyno Tuning, and FREE CLOWNS!
Old Apr 11, 2016 | 01:20 PM
Schister66's Avatar
Man U FTW
Is that Devcon? I haven't seen that done since back in the days of Hotrex and Crazy Horse 40's
Reference: WRITE-UP DIY BLOCK FILLING | HondaSwap & https://honda-tech.com/welding-fabri...lcome-1444721/
98_Milano_Teg
Jan 30, 2012 03:35 AM
black_EM1
Dec 29, 2011 11:42 AM
Eli2
Apr 3, 2009 10:34 AM
JoseCuervo
Feb 14, 2006 02:02 AM
EJ8 GSR-T
Feb 10, 2006 09:08 PM
