Power to the fuel pump
I got the airtex pump from the drag three kit.
I need to know where to connect the power for the pump at. Does it connect to the fuse box or what? Please be very discriptive or show me pictures thanks alot. http://images.zeroforum.com/smile/emcocktl.gif 00' Integra GSR |
Re: Power to the fuel pump (BVM)
I know you guys have the awnser...
Ill be up and running I just need this. http://images.zeroforum.com/smile/emthup.gif thanks http://images.zeroforum.com/smile/emcocktl.gif |
connect it to the fuel pump relay that is located under the dash you shoud be bale ot here it click whe nyou turn the key on. The other alternative is run it an accesory with an inline fuse
Yup, as B18bturbo says, locate the main relay. It's usually under the instrument cluster on most Hondas but on newer Civics and Si's it's located under the dash closer to the passenger side. You can hear it clicking on and off if you keep cycling the ignition key between ignition 1 and ignition 2 positions. The wire you want to tap is usually pin 7 or pin 4 on the relay (yellow/black stripe). If you are unsure which wire is the correct one, use a test light and see which wire lights the test light for about 1 sec, then turns off when you turn the ignition key from ignition 1 to ignition 2. You'll see hear the factory pump buzz on and off in tandem with the light when you find the correct wire.
