Potential 95 Accord turbo build
Hey guys, so I have really been looking into turboing my 95 accord ex coupe. I plan on building it on a budget and using whatever I can. My car has a F22 non vtec and a 5 speed manual. Right now I plan on using the turbo from my friends WRX when he upgrades to a larger one, or possibly a turbo from another car, but I have some questions.
1) How much boost would the stock internals be able to handle? I don't plan on building the F22, but I also plan on keeping boost pretty low, less than 10-15psi
2)Can the stock ECU be tuned? or do I need to purchase an aftermarket computer?
3)What size injectors would you guys recommend for a set up like this?
I'm sorry if these have already been asked, I just had a few questions so I thought I'd post up. I also did this to get some feedback and advice, thanks everybody!
It's wU to the sOLdiEr!
Re: Potential 95 Accord turbo build
Turbo on a budget, just doesn't sound right to me. Anyways, do you know of a manifold that can work your car at that turbo from the wrx? Chances are you'll need a custom made manifold and that will cost a lot.
Go though this topic a couple of times my friend
https://honda-tech.com/forums/showthread.php?t=1024174
yes, stock cpu can be tuned
400 cc injectors is ok for stock engine
IMO stock internals can handle about 250 hp
i agree with justYn you must read the faqs...
By "on a budget" I meant by using parts from other cars like the turbo itself. Not like cutting corners. And I have been looking. I guess I was looking more specifically at using the turbo from the wrx, but if it is too small to be worth it, I will look for something a bit bigger. Thanks guys
the wrx turbo (td04-13G) is very small for the h22, I suggest you get a used TD05-16G from mitsu lancer evo, and have it rebuilt.
Man U FTW
Before doing anything, read the Forced Induction FAQ...it will save you a lot of headaches if/when you build this setup
garyvan510
07-17-2009 03:03 PM
