Post your pump+meth setups
Old Aug 8, 2013 | 05:11 PM
ballistic1350's Avatar
Default Post your pump+meth setups
Looking for dyno plots and install pics of different meth setups. I had a twin nozzle aquamist setup on my sti and loved it. Looking for options on my honda as well as how others integrate them and provide failsafes.
Please Include:
system being run
nozzle size
water meth %
install location
dyno
any other useful data...
Old Aug 9, 2013 | 04:41 AM
89efhatchy's Avatar
Default Re: Post your pump+meth setups
I'm using a Snow Performance progressive meth kit on mine with the largest nozzle. I have it plumbed in about 3"-4" from the throttle body.I'm using Snow Performance Boost Juice. We haven't put the car on the Dyno yet. Hoping to make between 400-450 on 93/meth. We use a mustang Dyno btw.
You can barely see the nozzle here.
Better pic.
Old Aug 9, 2013 | 05:32 AM
Any reason you chose the snow performance kit over aem or aquamist?
Old Aug 9, 2013 | 05:51 AM
89efhatchy's Avatar
It's just what we sell and use on 75% of the customers cars that come through the shop. Before this, I used a coolingmist kit back when I had my neon. Besides a pump seizing up (which was bought second hand) in a 4 year period, it worked well also. I don't have any experience with aquamist, but I'm sure they work well also. On the neons, we typically see 40-50whp gains with meth. I planned to run this car on e85 but it's gotten too hard to get a hold of around here so this seemed like the best option.
Old Aug 9, 2013 | 05:59 AM
yeah its hard to get e85 around me so I figured I'd dive back into meth injection. I absolutely loved my aquamist setup from before, although it was kinda pricey... anyway more meth setups please
Old Aug 9, 2013 | 06:44 AM
92cxyd's Avatar
Originally Posted by ballistic1350
yeah its hard to get e85 around ...... anyway more meth setups please
+1 and I'm curious as to nozzle placement, including (if any) pre-turbo.
Old Aug 9, 2013 | 09:22 AM
89efhatchy's Avatar
I've always heard bad things about spraying meth into the turbo. On my bosses neon, we did used to spray water straight at the center of the wheel. Not sure how much it really helped though.
Old Aug 9, 2013 | 10:26 AM
TheShodan's Avatar
Moderator
It didn't. Its like almost hydrolocking an engine. its trying to compress water at that point.
Old Aug 9, 2013 | 11:27 AM
yungkhmer's Avatar
im saving up for a devils own meth kit. anybody ever use it?
Old Aug 9, 2013 | 12:45 PM
89efhatchy's Avatar
I'd be surprised if it didn't help a little with cooling.
Old Aug 9, 2013 | 01:41 PM
TheShodan's Avatar
Moderator
Please re-read the article as well as its interpretations stated above. that is the caveat.. (The BUT... Before you get excited). The "cooling" is only an after effect because there is a higher risk of the compressor wheel compressing FLUID that's before its flashpoint and will errode the wheel.
Stop thinking one dimensionally with regards to "COOLING". It doesn't mean crap if your compressor wheel is damaged from housing contact because it tried to compress a liquid.
Old Aug 9, 2013 | 02:57 PM
anyway back to meth setups... there is another thread on pre-turbo injection
Old Aug 9, 2013 | 05:31 PM
TheShodan's Avatar
Moderator
Thanks.. Finally
Old Aug 10, 2013 | 09:39 AM
aleEvo's Avatar
aem kit
Upgrade from me
ais steel check valve
direct port nozzle
4x252cc ais nozzle
50/50 mixture
dyno number coming soon
Old Aug 10, 2013 | 09:45 AM
duf2570's Avatar
Originally Posted by aleEvo
aem kit
Upgrade from me
direct port nozzle
4x252cc ais nozzle
50/50 mixture
nice setup here
Old Aug 10, 2013 | 10:04 AM
Running any kind of failsafe?
Old Aug 10, 2013 | 10:05 AM
aleEvo's Avatar
not for now
Old Aug 10, 2013 | 10:09 AM
Any more pics of bottle location or close up of where you tapped in the nozzles?
Old Aug 10, 2013 | 10:14 AM
aleEvo's Avatar
for now I only bottle location
Old Aug 10, 2013 | 10:16 AM
aleEvo's Avatar
similar location nozzle
Old Aug 10, 2013 | 10:17 AM
Nice little setup you got. Why aem though? It seems like one of the simplest systems out there
Old Aug 10, 2013 | 10:32 AM
aleEvo's Avatar
because before I used the kit aem ...... then I decided to upgrade
aquatech pump is like many other kits
aem to have only the progressive controller and bottle, which seems to work well
Old Aug 11, 2013 | 04:41 PM
Skip01's Avatar
Anyone ever run meth without a intercooler setup?
Ive seen it a couple times on domestic...but not more than 15psi....not sure if that matter just saying
Old Aug 13, 2013 | 05:33 AM
any more setups out there?
Old Aug 15, 2013 | 10:21 AM
Nbboy7's Avatar
AEM meth kit running 51-water 49-meth mixture with 93 pump. Fail safe to hondata s300 for boost cut and timing. Running the largest nozzle that come with the kit.
PeakBoost
Mar 10, 2005 09:58 AM
mister2racer
Sep 30, 2003 01:32 AM
G-MO
Nov 19, 2002 05:37 AM
David@DSport
Jul 13, 2002 11:57 AM
