Earthing systems...
Old Jul 11, 2002 | 07:24 PM
David@DSport's Avatar
Default Earthing systems...
It has been brought to my attention that there was a debate over earthing systems.
I have been tring to get another car on the dyno for the past week or so but our garage has been to busy lately. I was there when the sir went on the dyno before and after the install of the earthing system. The reason that you don't feel the horsepower it makes is due to the fact that it makes power in such a broad powerband without any spikes. As you may know, usually most aftermarket bolt ons will create a spike in the powerband. This spike is what makes you think your car is faster. Now, if you use a product that makes power across the entire rpm range, you wouldn't feel it because it stays smooth. The kit made 4whp from 4000-9500rpm. Can you feel the difference?Not a chance! Dynos don't lie though. As soon as we have time I will dyno again and will post the results.
Old Jul 11, 2002 | 08:02 PM
frogsr's Avatar
Default Re: Earthing systems... (****@A51)
looking forward to seeing some dynos. make it comprehensive please...
Old Jul 11, 2002 | 08:15 PM
Austin's Avatar
Looking forward to it shaggy...didn't know that anyone other than Robbie posted on here.
Austin
Old Jul 11, 2002 | 09:24 PM
oldskool_rex's Avatar
lol, hey ****, I got more posts than you!
Old Jul 11, 2002 | 10:31 PM
sa21199's Avatar
can someone to me explain what is the earthing system ?
Chris's Avatar
Default Re: Earthing systems... (sa21199)
its just better, bigger ground wires for the motor.
Old Jul 11, 2002 | 10:34 PM
01PYITR's Avatar
Default Re: Earthing systems... (Chris)
"can someone to me explain what is the earthing system ?
its just better, bigger ground wires for the motor."
WTF I'm lost...
Old Jul 11, 2002 | 10:45 PM
Tommy_Gunns's Avatar
Default Re: Earthing systems... (01PYITR)
https://honda-tech.com/zerothread?id=213972
It was suppose to be a how-to article but it turned into a does it work article
Old Jul 11, 2002 | 11:06 PM
Paul Walker's Avatar
yes sir
Old Jul 11, 2002 | 11:08 PM
uNF$@#!'s Avatar
Default Re: Earthing systems... (Paul Walker)
dyno please! ...4 whp! thats a substantial gain...
Old Jul 11, 2002 | 11:10 PM
AJ PwR's Avatar
I am sure it does make a difference.
Old Jul 12, 2002 | 06:20 AM
Default Re: Earthing systems... (AJ PwR)
TTT for david.
Paul, who will be doing the write up.
Old Jul 12, 2002 | 06:25 AM
tonyxcom's Avatar
On the way to good guys!
Old Jul 12, 2002 | 06:44 AM
DutchITR1689's Avatar
What is the measurement error? What happens if you don't change anything on the car and dyno it like 5-10 times. What will the variance be?
Old Jul 12, 2002 | 07:26 AM
jond's Avatar
Default Re: Earthing systems... (DutchITR1689)
Good questions.
If it turns out to be true, and it only cost $35, thats a damn good deal.
Old Jul 12, 2002 | 07:35 AM
Default Re: Earthing systems... (tonyxcom)
heheh tony you have 1337 posts.. LEET
Old Jul 12, 2002 | 08:45 AM
The dyno runs were back to back within 5 minutes of each other. Variances are very low. And trust me I was a bigger skeptic than anyone else at the shop. The dyno proved me wrong. I'm a believer now.
Old Jul 12, 2002 | 07:03 PM
You believer you!!!
Old Jul 12, 2002 | 07:08 PM
ITR21's Avatar
4whp is gold for 35 bucks!!!!!!!
Old Jul 12, 2002 | 07:32 PM
d8168055's Avatar
Default Re: Earthing systems... (ITR21)
after reading that post from a while back... i also want to see some results...
Old Jul 12, 2002 | 08:44 PM
CPR's Avatar
CPR
What earthing system was installed on the car that gave it 4whp?
Old Jul 13, 2002 | 12:22 AM
ILOVEGIRLS's Avatar
Default Re: Earthing systems... (CPR)
will this work on all applications? n/a.. turbo
how many points did u ground?
[Modified by ILOVEGIRLS, 1:23 AM 7/13/2002]
Old Jul 13, 2002 | 07:12 AM
I ask that because I have seen some dyno graphs of the same car dynoed within 1/2 hour and the variance was about 5 whp....
And what do you mean by low? 1 whp? 4 whp?
Old Jul 13, 2002 | 07:16 AM
Rob :190:'s Avatar
Default Re: Earthing systems... (ILOVEGIRLS)
shouldnt matter, theoretically should have similar effects for all. for the points, check the link in an above post.
Old Jul 13, 2002 | 09:00 AM
This was one by sun automobile which they have at their shop.. They should be also able to get the spoon ones for you spoon wh0res
[Modified by Paul Walker, 10:04 AM 7/13/2002]
