to post or blockgaurd
Old Sep 18, 2003 | 09:14 PM
phatrick2332's Avatar
Default to post or blockgaurd
12-14 psi on a stock y8 block...zdyne gold...post it or blockgaurd
im leaning towards posting it
thanks
if posted with zdyne, how high can i boost on the b16/supra piston setup(~8.2:1 comp)
Old Sep 18, 2003 | 09:29 PM
tegasaurus's Avatar
Default Re: to post or blockgaurd (phatrick2332)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by phatrick2332 &raquo;</TD></TR><TR><TD CLASS="quote">12-14 psi on a stock y8 block...zdyne gold...post it or blockgaurd
thanks
if posted with zdyne, how high can i boost on the b16/supra piston setup(~8.2:1 comp)</TD></TR></TABLE>
either way you must bore/hone it, its your call
Old Sep 19, 2003 | 09:41 PM
ive heard posting is a bit better, and i can do it myself. I kno neither really do much, its that whole piece of mind thing lol
instead of building my boost level around my setup..im building my setup around the boost level..good idea??
Old Sep 19, 2003 | 10:19 PM
infinatenexus's Avatar
Go with the posting. Its 36.00 for the parts from ENDYN, and takes about an hour to do. It will support the top, and middle of the cylinders, unlike a block guard that only supports the top. I have done it abotu 5 times, and its so easy, its not even funny.
http://www.muller.net/sonny/crx/engine/posted.html
Old Sep 19, 2003 | 11:03 PM
Sonny's Avatar
Default Re: (infinatenexus)
That engine looks really familiar.
Sonny
Old Sep 19, 2003 | 11:47 PM
sporkcrx's Avatar
Default Re: (Sonny)
****, for 14 psi I think your sleeves will be fine. If you have aftermarket rods/pistons it should last.
Old Sep 19, 2003 | 11:52 PM
sporkcrx's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by infinatenexus &raquo;</TD></TR><TR><TD CLASS="quote">Go with the posting. Its 36.00 for the parts from ENDYN, and takes about an hour to do. It will support the top, and middle of the cylinders, unlike a block guard that only supports the top. I have done it abotu 5 times, and its so easy, its not even funny.
What was used to seal the posts on that block?
Old Sep 19, 2003 | 11:57 PM
turbopanda's Avatar
Default Re: (sporkcrx)
I've lived with blockguards in my D16Y8 turbo, and B18C turbo - pushed over 1.7 bar on the D16Y8 a couple times (with my hybrid piston/rod package) and didn't have a problem
Old Sep 20, 2003 | 12:08 AM
Mine were TIg welded in place,, but I am sure there is some type of aluminum epoxy that will work just fine. go to the forums on the Endyne homw page,, I thike there is a thread about it
Old Sep 20, 2003 | 12:15 AM
turbopanda's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by phatrick2332 &raquo;</TD></TR><TR><TD CLASS="quote">if posted with zdyne, how high can i boost on the b16/supra piston setup(~8.2:1 comp)</TD></TR></TABLE>
If tuned right, you can push around 18psi safely on a daily basis.. you can go higher, but its at your own risk. I've boosted very high in the past, and the rods/pistons seemed to be able to handle the power (though its not something that I did on a regular basis)
Old Sep 20, 2003 | 12:20 AM
You do know any one with a band saw can make the post. They are just bar stock aluminum thats threaded. All you do is cut it to the size you want, and cut a slot in the end so you can tighten them with a flat head screw driver. Get a couple in on the deal, and I can supply them far cheaper than anybody else,,,
Old Sep 20, 2003 | 12:30 AM
Sonny's Avatar
Don't put slots in them. If you use a screwdriver to tighten them, you will overtighten them.
Sonny
Old Sep 20, 2003 | 12:35 AM
So how do you tighten them? I have never had a problem with mine, and they are the same style as the Endyn product.
Old Sep 20, 2003 | 12:46 AM
I can make them either way though,,,lol
Old Sep 20, 2003 | 05:53 AM
V3locity's Avatar
Bump for a great post that i've been debating myself. I've been kinda leary about posting my block. It's kinda new to me and I don't want to **** up my LS. How much does it help??
Old Sep 20, 2003 | 10:12 AM
it helps greatly,,, if you got F/I its awsome
Old Sep 20, 2003 | 10:35 AM
V3locity's Avatar
how much more approx. could I turn up the boost??
Old Sep 20, 2003 | 10:51 AM
Honestly man I have no clue,, I am the D series guru,, the B series is not my bag,,,lol
Old Sep 20, 2003 | 11:01 AM
MikeExt's Avatar
New User
So 18psi daily on a posted block, would that be the same for a D16Y8 block with let's say uh, 9:1 CP pistons, Eagle Rods, Blockguard and Hondata? Would it be a certain psi or a certain HP rating?
Old Sep 20, 2003 | 11:05 AM
I have seen 14-16 PSI on a posted D-16 Y8 with forged internals, huge intercooler,head studs, comptech head hasket,and Hondata
Old Sep 20, 2003 | 11:12 AM
MikeExt's Avatar
New User
Yeah that's what I run now is 14-15psi, but it's with a small turbo. Just wondering if 18psi on a T3 60/.48 a/r would be pushing it too far
Old Sep 20, 2003 | 11:17 AM
one way to find out,,,lol. I remember reading somewhere that if properly stabulized the D series sleeves could be pushed to 18 PSi,,,,, but I don't remember where I saw that
Old Sep 20, 2003 | 01:56 PM
turbopanda's Avatar
i've pushed well over 18psi on my stock d16y8 sleeves (only blockguard to help support them) and i had no problems at all. Blockguards get their bad name from those who don't have them installed properly, and for those who don't have the blockguard water holes lined up with the holes on the headgasket.
Old Sep 20, 2003 | 02:07 PM
Dude,, your crazed,, in a good way
Old Sep 21, 2003 | 07:36 PM
mugensport9's Avatar
Default Re: to post or blockgaurd (tegasaurus)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tegasaurus &raquo;</TD></TR><TR><TD CLASS="quote">
either way you must bore/hone it, its your call</TD></TR></TABLE>
why would he have to bore?
