Possible blow by?
Old Aug 8, 2007 | 03:32 PM
xtrec02's Avatar
Default Possible blow by?
Modified by xtrec02 at 11:43 PM 6/30/2008
Old Aug 8, 2007 | 03:46 PM
Coppertop's Avatar
Default Re: Possible blow by? (xtrec02)
my friend has a turbo miata and his might have smoked a little bit out of the VC but he has some bad blow by to where its breakin the seal on the oil pan
Old Aug 8, 2007 | 03:51 PM
xtrec02's Avatar
Default Re: Possible blow by? (Granger)
Old Aug 8, 2007 | 05:29 PM
urbansi's Avatar
Same thing happened to me when i blew a couple ringlandings, does the motor run differently at all, have you tried doing a leak down test or compression test yet?
When my motor went it actually blew through the autozone filter metal top and created a decent hole.
good luck
Old Aug 8, 2007 | 05:36 PM
tony413's Avatar
possible bent valves is there any noise that you can hear at idle ??? when you rev the engine does the noise lessen ???
Old Aug 8, 2007 | 05:40 PM
urbansi's Avatar
Default Re: (tony413)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tony413 &raquo;</TD></TR><TR><TD CLASS="quote">possible bent valves</TD></TR></TABLE>
exactly why a leak down test would be in order, closing each valve(s) on each cylinder will track down where it is coming from if you think there is a bent valve, the air will either divert through the exhaust or back to the intake manifold...
Old Aug 8, 2007 | 05:45 PM
tony413's Avatar
Default Re: (urbansi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by urbansi &raquo;</TD></TR><TR><TD CLASS="quote">
exactly why a leak down test would be in order, closing each valve(s) on each cylinder will track down where it is coming from if you think there is a bent valve, the air will either divert through the exhaust or back to the intake manifold...</TD></TR></TABLE>
this way may take longer but it works take the head off an spray some WD-40 if any of it leaks from the valves your valves are bent
urbansi where can one buy a leak down kit ???
Old Aug 8, 2007 | 05:48 PM
urbansi's Avatar
I had a make your own kit online that i found a while back, just do a search for a DIY leak down tester online, you will also need an air compressor for you information
Old Aug 8, 2007 | 07:45 PM
tony413's Avatar
ok thanks ill try that
Old Aug 8, 2007 | 08:27 PM
xtrec02's Avatar
bump
Old Aug 8, 2007 | 08:42 PM
tony413's Avatar
did you try any of the things we said before you bumped the thread ?
Old Aug 8, 2007 | 08:49 PM
xtrec02's Avatar
Default Re: Possible blow by? (tony413)
Old Aug 8, 2007 | 09:56 PM
SOHC_MShue's Avatar
your ringlands are probably done
teg racer 877
Oct 13, 2008 03:34 AM
B20inDCinLBC
Oct 21, 2006 09:40 PM
Baron55
Dec 24, 2005 08:02 AM
slowone
Aug 27, 2003 06:36 AM
JdmIntegra98
Jul 3, 2003 03:58 PM
