positive boost onset range for drag3?
Old Dec 22, 2001 | 10:20 AM
redteg1's Avatar
Default positive boost onset range for drag3?
at around wat rpm range does all hell break loose for the drag 3 on a teg
Old Dec 22, 2001 | 10:41 AM
chri5's Avatar
Default Re: positive boost onset range for drag3? (redteg1)
all hell breaks loose around 4k in my car, but keep in mind I still have stock exhaust and I'm sure that is killing my spoolup time.
Old Dec 22, 2001 | 11:01 AM
ekb18c's Avatar
Default Re: positive boost onset range for drag3? (Strng1dah)
Around 4k sounds about right. Depends on the turbine offcourse. I'm assuming that you have a t3/t4oe thats usualy comes with the drag kits. So 4k sounds about right.
HTH
Old Dec 22, 2001 | 02:09 PM
Anthony K's Avatar
New User
I have a Greddy EVO exhaust and all hell doesn't really break loose until roughly 4k either. I can hear it spool up pretty fast, but good boost doesn't generate till then. I guess spool up doesn't really change when going from stock to ~2.5 aftermarket. Maybe a 3 inch exhaust might help?
Old Dec 22, 2001 | 02:50 PM
ekb18c's Avatar
Default Re: positive boost onset range for drag3? (Anthony K)
3 inch REALLY HELPS!!! Anyone with a forced inductions system should Get a 3 inch exhaust.
Death_to_Thieves
Feb 21, 2008 04:42 PM
sway892
May 19, 2004 02:03 PM
z6
May 18, 2004 07:47 PM
mitsuman
Apr 9, 2004 02:34 PM
01ITR#700
Sep 5, 2002 12:27 PM
