Boost loss due to exhaust?
Old Sep 5, 2002 | 08:15 AM
01ITR#700's Avatar
Default Boost loss due to exhaust?
I had a few questions regarding losing boost pressure with small exhaust. When I initially got my car running at 4psi I was running an open 2.5" manrel bent downpipe for a day or two. The car ran strong and pulled to 4psi EXTREMELY fast and hard. Now I temporarily "Plugged" the 2.5DP into the Stock Type R exhaust. After that it only goes to 2psi and holds there. At that point I assumed (but couldn't believe) that the stock exaust was just too restrictive, so I added a vacuume T into the line coming off the WG to make sure it would still boost above 2psi w/ stock exhaust. With the T in there it went back up to 4.5-5psi, but it didn't pull as quickly or as strong.
So the main question is if it's possible to lose 2psi just from stock exhaust?
Is it OK to use the "T" trick to raise the boost back up with the stock exhaust connected?
BTW I'm running the Tial 35mm WG w/ what appears to be a 4psi spring(yellow)
Thanks for any info.
Mark
Old Sep 5, 2002 | 08:20 AM
ekb18c's Avatar
Default Re: Boost loss due to exhaust? (01ITR#700)
Yes, a smaller exhaust will restrict the the turbo. Let it breath dude!
Old Sep 5, 2002 | 08:25 AM
01ITR#700's Avatar
Default Re: Boost loss due to exhaust? (ekb18c)
Haha, I know but I though 2psi from Type R exhaust seemed like a lot. A full custom 3" exhaust is in the works but won't be done anytime soon.
M
Old Sep 5, 2002 | 12:27 PM
SIK IN DA HED's Avatar
New User
open up that exhaust man! ENUFF SAID!
skrigz
Mar 17, 2006 07:38 PM
mitsuman
Apr 9, 2004 02:34 PM
DXturbo
Jul 9, 2003 09:22 AM
Diego Boost
Feb 1, 2003 11:12 AM
