Poor Man's Type R Turbo Question
Old Apr 7, 2009 | 07:34 PM
Bonestock98GS's Avatar
Default Poor Man's Type R Turbo Question
Alright I bought a 94 civic with a GSR Block and a B16 head. It has JE 12:1 Pistons stock rods and ARP rod bolts. I know its built for NA but I dont like all motor and I wanted some advice on if I should turbo it or not? I know 1 thing for sure and thats if it has a good tune thats all that matters so I need some suggestions
Old Apr 7, 2009 | 07:38 PM
amimaxima's Avatar
Default Re: Poor Man's Type R Turbo Question
small turbo low boost?
Old Apr 7, 2009 | 07:42 PM
ABK's Avatar
ABK
I wouldn't. Sell the motor buy a stock motor or build one and boost it.
Old Apr 7, 2009 | 07:46 PM
Yea I have a small turbo and I was thinking low boost also. I have a .50 trim turbonetics. I really dont want to go through taking the motor out and putting a new one in. I just want to know if it would work or not because I've been told High Comp. motors make good power but you just cant run a bunch of boost
Old Apr 7, 2009 | 07:51 PM
TheShodan's Avatar
Moderator
Higher than normal compression on a VTEC honda yes. High compression like 12:1, NO. you need to drop that a bit to about 10-11.0:1. Unless you can tune your *** off.
Old Apr 7, 2009 | 07:59 PM
You are the perfect person to chime in (respect to everybody else) But Shodan my question is how would I be able to drop the CR that low? thick headgasket? If I can get ways to drop it low enough I will do that instead of boosting it as it sits now
Old Apr 7, 2009 | 09:02 PM
Any suggestions on steps to lowering my Compression Ratio?
Old Apr 7, 2009 | 09:05 PM
cvcrtonv's Avatar
change the pistons, stay away from thicker headgaskets
Old Apr 7, 2009 | 09:07 PM
Whats bad about a thicker headgasket? changing the pistons shouldnt be too bad should it?
Old Apr 9, 2009 | 07:43 PM
ABK's Avatar
ABK
lol it's easier to swap the motor out. and those rods have bushings installed in them for full floating pistons. So you would either have to run stock pistons and new set of stock rods, full floating pistons or forged pistons and h beam rods.
03EM2guy
Nov 23, 2011 09:17 AM
92civtegra
Aug 15, 2007 08:26 PM
93_delsol_si_gsr
Aug 31, 2006 07:15 PM
MobRacing2
Feb 24, 2006 06:43 AM
Scubster
Dec 16, 2004 10:54 PM
