plugs and gapping
Old Feb 26, 2008 | 04:36 PM
2000siturboR's Avatar
Default plugs and gapping
any idea what plugs to run on a turboed b16a2 on 7 pounds with chipped p28 and 310 cc injectors i tried i think they were brk7e's on 0.25 and changed them to 0.30 and at idle its still missing and its not in the motor compression is good. might need a colder plug. any ideas
Old Feb 26, 2008 | 04:42 PM
Schister66's Avatar
Man U FTW
I run BKR7e's in my GSR...they'll be fine for you. I'm not sure exactly what could be causing the misses, but as for the plugs, you're fine. I always gapped mine at a .32 FYI.
Old Feb 27, 2008 | 07:01 AM
blackcherry's Avatar
i have the op setup on my gsr for the mostpart. same plugs and gap but idles wonderful. im not even tuned yet, just a typer revhard basemap. we need more info about your car to help determine why its missing like that. do you have cams?
Old Feb 27, 2008 | 04:31 PM
Default Re: (blackcherry)
the motor is a b16a2 with greddy turbo kit on 7 pounds and no its not running of the that stupid emanagement the only thing internal are some eagle rods a je low compression pistons. and no cels nothing just had the motor rebuilt plugs and wires are new dunno why its idle low and missing and its also running rich and just got it tuned about a month ago dunno.
Modified by 2000siturboR at 8:44 PM 2/27/2008
Old Feb 27, 2008 | 05:32 PM
it could be a number of things but since its built bottom end, how is the head? did you have a machine shop work on the head? even then they could have f'ed something up with the valves and cause it to miss like that
Old Feb 27, 2008 | 05:49 PM
batboyvaj's Avatar
you sure you have the wires in the correct firing order?
Old Feb 27, 2008 | 07:52 PM
Evilparadize's Avatar
Check for proper voltage at each of the injectors. Sometimes new components are bad or don't work well with others, so take them to RC for a proper clean and balance (guessing $140.00), they'll provide you with a flow chart. Check your ignitor, coil, plugs and wires, make sure you have a nice strong spark. If it's running rich after tuning, I would look into another tuner (air/fuel tables and timing off), but definitely check the simplest and obvious parts first.
hksitr
Sep 12, 2011 03:03 PM
93 Eg Couper
Aug 20, 2010 03:20 PM
flangemastermike
Nov 15, 2008 08:00 PM
LSVTECoupe
11
Jul 8, 2003 08:45 AM
tnbigdawg
Dec 23, 2002 02:41 PM
