Plugging squirters?
Old Dec 12, 2004 | 09:48 PM
crispydee's Avatar
Default Plugging squirters?
I've read a thread that mentioned this, whats it about?
Old Dec 12, 2004 | 09:57 PM
Archidictus's Avatar
Unceasing Measure
Default Re: Plugging squirters? (crispydee)
Forged rods and pistons don't necessitate oil squirters, so many people reduce the moving parts/valves/mess by plugging them - which also increases systemic oil pressure.
Eagle just came out with a kit for it and, if I do say so myself, it looks hawt.
Old Dec 13, 2004 | 12:29 AM
crispydee's Avatar
Default Re: Plugging squirters? (Archidictus)
Ok i understand, so this is not some thing i need to do as im building my motor as soon as my pistons come. Might be a stupid question but why dont the forged pistons and rods not need as much lubrication?
Old Dec 13, 2004 | 06:11 AM
platinum00's Avatar
is there any advantage to this besides increased oil pressure.
any side effect ?
platinum.
Old Dec 13, 2004 | 06:45 AM
VTECisSeXY's Avatar
*insert here*
Default Re: Plugging squirters? (platinum00)
mike is a PIMP
Old Dec 13, 2004 | 06:50 AM
snoochtodanooch's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crispydee &raquo;</TD></TR><TR><TD CLASS="quote">Ok i understand, so this is not some thing i need to do as im building my motor as soon as my pistons come. Might be a stupid question but why dont the forged pistons and rods not need as much lubrication?</TD></TR></TABLE>
its not a lubrication issue as much as it is a cooling issue with the oil squirters from what i have heard. The forged pistons dissipate heat more easily than the stock pistons, thus not necessarily needing the extra oil being sprayed to cool them.
plus it eliminates some aireation &lt;spelling?&gt; of the oil, making the whole oil system perform better, not to boot it raises the oil pressure which is even better.
Old Dec 13, 2004 | 07:50 AM
Jared's Avatar
Default Re: Plugging squirters? (snoochtodanooch)
golden eagle has plugs now that are the same pitch and thread as the holes. that way you dont have to tap the holes, clean metal shaving, put in pipe taps, all that crap.
Old Dec 13, 2004 | 08:29 AM
m R g S r's Avatar
Default Re: Plugging squirters? (Jared)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jared &raquo;</TD></TR><TR><TD CLASS="quote">golden eagle has plugs now that are the same pitch and thread as the holes. that way you dont have to tap the holes, clean metal shaving, put in pipe taps, all that crap.</TD></TR></TABLE>
Damn, I just paid earl $50 to do that along with my other engine work. .
Old Dec 13, 2004 | 08:44 AM
PM-Performance's Avatar
Default Re: Plugging squirters? (m R g S r)
bahhh, i kept mine in all my blocks and worked fine
Old Dec 13, 2004 | 10:19 AM
onePOINTsix's Avatar
Default Re: Plugging squirters? (itr206)
on some built motors the pistons or rods (cant remember which) can hit the oil squriters. Best way to do it: Get yourself a 1/8" NPT tap and 4 1/8" NPT aluminum plugs. Rethred the holes with the tap, put some selant on the plugs and screw them into the newly tapped hole. Est. time, 30min at most
Old Dec 13, 2004 | 01:08 PM
MrBui's Avatar
Default Re: Plugging squirters? (onePOINTsix)
no best way is to buy those plugs from GE i think somewhere around 10 bucks
Old Dec 13, 2004 | 02:37 PM
SiRex91's Avatar
Default Re: Plugging squirters? (n20need4vtec)
Here you go: https://honda-tech.com/zerothread?id=1081578
Old Dec 13, 2004 | 02:42 PM
Unsivil_audio's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by snoochtodanooch &raquo;</TD></TR><TR><TD CLASS="quote">its not a lubrication issue as much as it is a cooling issue with the oil squirters from what i have heard. The forged pistons dissipate heat more easily than the stock pistons, thus not necessarily needing the extra oil being sprayed to cool them. </TD></TR></TABLE>
Werd.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by snoochtodanooch &raquo;</TD></TR><TR><TD CLASS="quote">plus it eliminates some aireation &lt;spelling?&gt; of the oil, making the whole oil system perform better, not to boot it raises the oil pressure which is even better.</TD></TR></TABLE>
Are you talking about the froathing (foaming) oil does when you agitate it? (as in it helps eliminate some of that?)
Old Dec 13, 2004 | 03:30 PM
Default Re: Plugging squirters? (Unsivil_audio)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Unsivil_audio &raquo;</TD></TR><TR><TD CLASS="quote">
Are you talking about the froathing (foaming) oil does when you agitate it? (as in it helps eliminate some of that?) </TD></TR></TABLE>
yea, same concept as using a dry sump system.
Old Dec 13, 2004 | 08:03 PM
92HB_HB's Avatar
better yet, just take off the squirters, cut off the angled nipples and weld the holes shut on the plugs and tighten them back into the treaded holes.. total cost.. FREE... or u can just go w/ GE..
DA9tothewheel
Mar 15, 2016 05:36 PM
RACEPAK
Oct 20, 2014 07:37 PM
CustomX113
May 11, 2007 07:01 AM
the.hamburglar
Sep 30, 2005 07:07 AM
