skidplates for turbo?
Old Feb 23, 2003 | 12:44 AM
JDEM1's Avatar
Default skidplates for turbo?
my cars pretty low and i dont want to mess up my downpipe and cat.. is there a company that makes skidplates for civic 99-00 or custom one to help protect my downpipe? thanks
Old Feb 23, 2003 | 07:23 AM
Tinker219's Avatar
Default Re: skidplates for turbo? (JDEM1)
just make one out of half inch steel...
oh you mean excess weight isnt good?
The only thing that you could do is fabricte something to bolt to the K frame, that encases the engine/tranny. THe only problem is you will bottom out a lot more...your call.
and no, nobody makes any skid plates for Hondas...
Old Feb 23, 2003 | 07:40 AM
falcongsr's Avatar
What is this crap?
raise your car up. 3 inch drop isn't cool anymore.
Old Feb 23, 2003 | 02:29 PM
JDEM1's Avatar
Default Re: skidplates for turbo? (falconGSR)
its less than a 3 inch drop.. but the thing im worried about is my killer driveway.. its steeper than a ****
Old Feb 23, 2003 | 02:53 PM
b16ahybrid's Avatar
do you bottom out often going up your driveway? generally the only time that you will hit your dp is when your going over a speed bump or hit a raised object in the road (manhole cover)...which is totally possible because around here the construction crews think that it's ok to shave 3'' off the road and leave it for about 2-3 weeks until they come back to resurface the road, so the manholes are raised about 3''..then they forget to put up a sign warning you.......or they don't make a gradual lip (going from old road surface to the shaved surface) so there is a 3'' lip that goes strait up...
Old Feb 23, 2003 | 02:57 PM
Tinker219's Avatar
Default Re: skidplates for turbo? (b16ahybrid)
ewww I know exactly what you are talking about there...
I watched a hydro'd S10 basically rip his Engine/frame/frame everything apart on one of those damned manholes It was pretty knarly...
Old Feb 23, 2003 | 03:32 PM
b16ahybrid's Avatar
Default Re: skidplates for turbo? (Tinker219)
Yeah i don't mind them as much as the people driving behind me....i'm used to the constructon zones so i go about 15mph so i don't hit those manholes (eventhough i'd probably clear it don't want to take the chance) and those lips i hate the most......i hit one going about 35mph one night .....it hit so hard my headlight (bulb) poped out of the lense (out the back) so i had to pull over to put it back in, and check to see if i had bent rims...luckly nothing else happend but i was soo pissed....i even went back to see if there were any signs posted ..there were none indicating a work zone or bumpy road....so now i just take my sweet time driving through them...
dointhemzs
Dec 4, 2008 04:46 AM
rough_draft
Jun 21, 2005 04:11 PM
Methane2k2
Dec 26, 2004 07:37 AM
turbo gli
Welding / Fabrication
21
Dec 17, 2004 09:57 PM
vaporboy12
Jan 16, 2004 08:14 AM
