please help w/ choosing pistons
Old Jul 4, 2007 | 06:02 PM
eglslsd's Avatar
Default please help w/ choosing pistons
im building an ls motor for boost and nos my brother is building a gsr for boost
what would be the right piston compression ratio to go with.
Old Jul 4, 2007 | 06:07 PM
nextel_31's Avatar
Default Re: please help w/ choosing pistons (eglslsd)
i think 9:1 for the boost only and 8:2 for the boost and nitrous
Old Jul 4, 2007 | 06:12 PM
eglslsd's Avatar
Default Re: please help w/ choosing pistons (nextel_31)
some one told me to use 9:1 for boost and nitros and told my brother to use 9:8:1
for his gsr because he has a small turbo td05 does this sound right?
Old Jul 4, 2007 | 06:42 PM
Schister66's Avatar
Man U FTW
if your brother is using a crappy little Mitsu turbo, hes not going to make enough power to justify building the engine...just a thought
Old Jul 4, 2007 | 06:43 PM
nextel_31's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eglslsd &raquo;</TD></TR><TR><TD CLASS="quote">some one told me to use 9:1 for boost and nitros and told my brother to use 9:8:1
for his gsr because he has a small turbo td05 does this sound right?</TD></TR></TABLE>you can use 9:1 if you want but it all depends how much nitrous and how often you are going to do it.
for your brother i think 9:8:1 will be fine. unless he is planning on bigger turbo and a lot more more boost with pump gas. but if he is going to run that turbo why he didn't stay stock bottom end will be find. i thinnk be a waste of money to change pistons just to run 10 pounds and 9:8. seriously. i will only change pistons andd rods if i will boost 15+ lbs. i thinks but good luck with both setups.
duf2570
Jan 13, 2013 04:29 PM
ludatic98
Mar 2, 2007 06:00 PM
k4rts
Nov 13, 2006 09:27 PM
tray3rd
Jun 11, 2004 10:05 AM
Aeka GSR
Sep 26, 2003 09:25 AM
