Please HELP!!! Tapping for oil feed....
Old Mar 15, 2003 | 11:54 AM
ridnmyhonda's Avatar
Default Please HELP!!! Tapping for oil feed....
ok i got my oil feed in today and i found where i'm tapping right in the back right next to the oil filter...i took off the wire running to the oil pressure thing...but now how do i get that piece off...it's in such an awkard place to get any tools too..any help? thanks
Old Mar 15, 2003 | 12:55 PM
Default Re: Please HELP!!! Tapping for oil feed.... (ridnmyhonda)
anybody
Old Mar 15, 2003 | 02:17 PM
Pengo's Avatar
after i got the rubber boot off i used an adjustable wrench from under the car and moved it little by little till it was loose enough to screw off by hand. if you use the right size box wrench it'll prob fit even better but i was just lazy
Old Mar 15, 2003 | 02:19 PM
Diego Boost's Avatar
Default Re: Please HELP!!! Tapping for oil feed.... (Pengo)
box wrench to break it loose and then unscrewed it by hand.
Old Mar 15, 2003 | 02:23 PM
intekragsr's Avatar
Default Re: Please HELP!!! Tapping for oil feed.... (Diego Boost)
you need a 15/16 deep socket. Its huge...the same size you use to remove the ect switch on the thermo housing. It just takes patience and sore shoulders to get back there.
I dont beleive a box wrench will fit in that area.
[Modified by intekragsr, 11:25 PM 3/15/2003]
CCarma
Aug 8, 2011 07:37 PM
avotegra
Sep 4, 2008 09:43 AM
spidermancivic
Jun 19, 2005 08:57 AM
JM Performance
Dec 8, 2001 11:03 PM
JohnShaft
Aug 22, 2001 12:09 PM
