Please help......problems
Old Sep 11, 2005 | 09:12 AM
Boosted_RsxS's Avatar
Default Please help......problems
Ok guys I bought a 2000 integra type r with a turbo kit on it......Now heres my problems: it has a msd boost retard on it which if i mess with it, the car stutters and wont gain any power at all.....when i got the car the timing was retarded 8 degrees plus the guy had the boost retard was retarding it 3 degrees from in the car.....I set the timing back to stock and turned the boost retard to 0 and i can drive it but not get on it hard...when the vtec and boost kick in it pulls hard and the boost holds right at 8 psi and doesnt spike at all...i ran 100 octane and it ran good but still had a slight stutter and of course the engine light came on saying the o2 was reading rich which i suspected would happen. the injectors are stock and there are two injectors in front of the throttle body which appear to be running off a gm 3 bar map sensor.....the orignal map on top of the throttle body has a missing link attached to it...its running off a stock ecu which im sure is one of my problems already.....This is the first boosted honda I have ever owned so im a noob at this...let me here what you guys think and stuff i should change....and I have been told to get 550 injectors and drop the two in the intake side....
Old Sep 11, 2005 | 11:25 AM
Default Re: Please help......problems (Spoolin_R)
man come on guys need input
Old Sep 11, 2005 | 01:10 PM
Tactic$'s Avatar
Step 1.
Remove MSD
Old Sep 11, 2005 | 01:14 PM
mrbsponge's Avatar
yes remove the MSD, go back to stock and re tune with something else.
if you do not have a good knowledge of MSD products and have no idea what the base timing was set at by the previous owner, you could be in for some trouble
take it off and start from stock, get some hondata, and if not atleast get someone to tune it on crome
warrick
Oct 28, 2006 02:28 PM
Endoe
Oct 7, 2004 07:11 AM
mattcalica
Oct 4, 2004 09:48 AM
R6Elmo
Feb 16, 2004 03:50 PM
JRSCCivic98
Jun 12, 2002 07:44 PM
