Please help with my D16 Drag setup.
Old Jul 2, 2002 | 08:02 AM
MyWhiteCivic's Avatar
Default Please help with my D16 Drag setup.
Me and my friend, John (thank God he knows what he is doing) are almost finished installing my turbo setup. Still have to drill the oil pan, hook up the oil feed/return lines, hook up the gauges, and install the downpipe (which didn't come with a flange dammit). But I need some help from you guys. What should I gap my spark plugs to? Right now, they are at .35 but I think that is way too big. What do you think? Also as of right now, I'm running a Vortech FMU because the Hondata 2bd has not come in yet. When I get the Hondata on, will I pass emissions? I heard that it will but if not, can I disconnect a piece of charge pipe and slap an air filter on it and run a 0 boost or stock chip on my Hondata to pass emissions?
Here's my setup:
1995 Honda Civic EX (D16Z6 engine)
Drag Gen 3 Turbo Kit w/ T3/T4 turbo (63 A/R 53 or 54 trim) @ 7 PSI
All the parts that came with the Drag kit (Vortech FMU, Spearco intercooler, some inline fuel pump)
Straight pipe
Borla axle back exhuast
As soon as Podium Performance sends my Hondata to me, my setup will look like this:
Drag Gen 3 Turbo Kit w/ T3/T4 turbo (63 A/R 53 or 54 trim) hopefully @ 9 PSI
Hondata 2b with Datalogging
Spearco intercooler
inline fuel pump
RC 440 injectors
Stillen FPR
Straight pipe
Borla axle back exhuast (until I can afford a Thermal)
Thanks in advance! I hope I gave enough info for you guys to help me out.
Old Jul 2, 2002 | 08:28 AM
CovertFI's Avatar
Default Re: Please help with my D16 Drag setup. (MyWhiteCivic)
i would leave them stock unless you upgrade your ignition.
Old Jul 2, 2002 | 09:18 AM
Default Re: Please help with my D16 Drag setup. (CovertFI)
I thought I needed a colder plug because of the turbo. I have read that many times.
Old Jul 2, 2002 | 10:17 AM
wwcivic's Avatar
New User
go ahead and get a colder plug and gap them to .30
I have ran ngk 2975ZFR7F-11's gapped to .30 and never had one problem.
Sonny's Avatar
Stock ignition gap is around .051". There's no way you can run a stock plug gap with FI without upgraded ignition. I ran my JRSC @ 8 psi with the plugs at .032" and never had a problem with the stock ignition.
Sonny
Old Jul 2, 2002 | 10:58 AM
Default Re: Please help with my D16 Drag setup. (wwcivic)
OK, great! Thanks for your help guys. But what about the Hondata? What should I do about emissions?
bigedx
Feb 24, 2004 07:33 PM
OoCanibus1oO
Aug 27, 2003 08:15 PM
Mr Samson
Oct 1, 2002 12:48 PM
MyWhiteCivic
Jul 2, 2002 11:16 AM
NickGSR
May 6, 2002 01:36 PM
