Does anyone here run a pop-off valve?
I don't see them too often, but they are used on a number of factory cars and Greddy and I believe HKS sells one.
But (in theory at least) they are the best way to protect against overboosting/spiking.
You could probably score one easily at a junkyard and it would be cheap insurance.
Anyone?
- Slater
[Modified by Slater, 11:50 AM 7/2/2002]
Anyone?
- Slater
Re: Does anyone here run a pop-off valve? (Slater)
i thought about that only when i hooked my wg up wrong. now i have no problems and dont want to spend the money for it.
Re: Does anyone here run a pop-off valve? (falconGSR)
i seen a couple mustang guys use it the pop off valve technology. It works very well in deed.
A pop-off valve is similar to the pressure relief valve on a N2O tank. Some what..
Once a maxumim pressure (in the intake manifold) is reached, the valve bleeds off pressure to stop an over pressure danger.
N20 tank relief valves release excessive pressure by breaking a small disk and venting out all of the N2O gas from the tank. The disk has to be replaced inorder to use the tank again.
Pop-Off valves relieve intake manifold pressure but I have seen smoe models that use a similar disk method and others that use a check valve system. The check valve is reusable after the excessive pressure contition is gone.
Fill in some info fellas, I'm sure I missed something?
[Modified by SLPR, 12:25 PM 7/2/2002]
