please help! miss-firing
Old Aug 19, 2003 | 05:07 PM
one more chance's Avatar
Default please help! miss-firing
just had my DC2 GSR turbo'd with a TD04, 3" exhaust w/dump-pipe, custom manifold, larger injectors and front-mounted intercooler. the system is being run buy an EMS stinger ecu and is currently getting a thorough tune. whilst tuning, we have discovered that as the turbo comes on boost, it misfires. cars stutters and is generally running like a *****.
changed the spark plugs, still nothing,
changed leads, still nothing
change the computer, still nothing...
injectors are totally new...
what else should i be looking at??? what other causes may there be...?
please help!!!
Old Aug 19, 2003 | 07:26 PM
red cx's Avatar
Default Re: please help! miss-firing (one more chance)
are you running stock ignition? check or swap the coil
Old Aug 19, 2003 | 07:58 PM
Blown90hatcH's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by one more chance &raquo;</TD></TR><TR><TD CLASS="quote">just had my DC2 GSR turbo'd with a TD04, 3" exhaust w/dump-pipe, custom manifold, larger injectors and front-mounted intercooler. the system is being run buy an EMS stinger ecu and is currently getting a thorough tune. whilst tuning, we have discovered that as the turbo comes on boost, it misfires. cars stutters and is generally running like a *****.
please help!!!</TD></TR></TABLE>
Whats your plugs/plug gaps?
Old Aug 19, 2003 | 08:33 PM
turbolsintegra26's Avatar
Default Re: please help! miss-firing (Blown90hatcH)
I had the same problem, I advanced timing 3-4 deg. and leaned out fuel mixture car runs awesome, no backfiring no fuel bog downs....
Old Aug 19, 2003 | 09:13 PM
Default Re: please help! miss-firing (Turbointegra22)
im running stock ignition for the time being...
not sure what gaps.......
anyone else...??is this purely an ignition issue or can there be other factors????
Old Aug 19, 2003 | 09:56 PM
uglyasscivic's Avatar
Start with spark plug gaps, try around .025 and if the sputter is still there it is probably your coil. I had the same prob today its is already fixed. Bad MSD coil
Also make sure you are using map as load. I have tuned a couple ems systems and for some reason the it had TPS and MAP as load with SOME base calibration files.
Old Aug 19, 2003 | 10:08 PM
Default Re: please help! miss-firing (uglyasscivic)
thanx bro....thats the answer i was searching for....
cheers...
Rtboy10
Feb 3, 2010 06:48 AM
top end tuner
Sep 24, 2007 08:41 PM
PY TYPE R 483
May 14, 2006 06:02 AM
evil93evo
Apr 10, 2006 03:21 AM
Integra GSR 95
Oct 29, 2005 06:27 PM
