First step to a Turbo set-up
Old Oct 29, 2005 | 05:46 PM
Integra GSR 95's Avatar
Default First step to a Turbo set-up
I have my entire turbo kit for my 95 GSR. Now I need the Turbo's for dummies book because I need to know what to get with it. I have the Intercooler and piping, BOV, wastegate manifolds gaskets and lines. Is it a must to upgrade the ECU? Can I just let the O2 sensor adjust everything? For the map sensor, is stock fine? Injectors on a GSR are they any bigger than most honda's? I plan to run 7 pounds btw. Any in put is helpful. Thanks.
Old Oct 29, 2005 | 05:52 PM
_gurusan_'s Avatar
Default Re: First step to a Turbo set-up (Integra GSR 95)
you don't have a complete turbo kit because you are lacking the MOST IMPORTANT THING: fuel management.
You MUST get larger injectors, and some way to control them. If you have a chipped ECU I can send you a basemap that will get you going until you can get it dyno tuned.
I recommend:
-tunertoys 450cc injectors
-Walbro 255lph fuel pump
-chipped ECU running a basemap (fuel enrichment in boost tables and step retard timing)
Do NOT run without these.
Old Oct 29, 2005 | 05:54 PM
TheBobFather's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Integra GSR 95 &raquo;</TD></TR><TR><TD CLASS="quote">I have my entire turbo kit for my 95 GSR. Now I need the Turbo's for dummies book because I need to know what to get with it. I have the Intercooler and piping, BOV, wastegate manifolds gaskets and lines. Is it a must to upgrade the ECU? Can I just let the O2 sensor adjust everything? For the map sensor, is stock fine? Injectors on a GSR are they any bigger than most honda's? I plan to run 7 pounds btw. Any in put is helpful. Thanks.</TD></TR></TABLE>
Upgrade ecu/ fuel management........yes ( hondata, neptune,ect)
O2 sensor adjust everything........no
map sensor fine for 7 psi.............yes/no ( either new 1 bar, or missing link/check valves)
injectors..............yes, get bigger ones
Old Oct 29, 2005 | 06:27 PM
whoneedzvtec's Avatar
Default Re: First step to a Turbo set-up (jnbhonda)
ur turbo kit did'nt come with an fmu?
Eric Kamphey
Mar 4, 2017 03:35 PM
dale187
Dec 8, 2008 10:04 AM
xxrjxx
Apr 5, 2008 06:45 PM
oh_lee_allen
Sep 18, 2007 10:07 AM
buffgsr
Mar 16, 2005 02:25 AM
