Please Help>>> How do I stop it???
Old Feb 10, 2006 | 03:47 PM
808_CRX_808's Avatar
Default Please Help>>> How do I stop it???
Hey Guys,
I'm new here. I'm running a B20/Vtech with a 100 shot of juice in my crx. I "backfired through the intake" they say, and it melted my map sensor blew my intake rubber fitting right off the throttle body. So I was just wondering if any one knew how I can avoid this? I have a JG Edelbrock intake manifold, injectors, Hondata ECU, stock throttle body, and a 100 shot wet nx. Please any suggestions?
Thanks...
Old Feb 10, 2006 | 04:09 PM
Default Re: Please Help>>> How do I stop it??? (808_CRX_808)
BUMP>>> GUYS PLEASE HELP>>>
Old Feb 10, 2006 | 06:15 PM
HEEEEEELLLLLLPPPPPPP>>>>>>......
Old Feb 10, 2006 | 06:32 PM
speedworks's Avatar
what rpm are you hitting the nitrous sir?
Old Feb 10, 2006 | 08:53 PM
allmotoreglsvtec's Avatar
Default Re: Please Help>>> How do I stop it??? (speedworks)
try hitting it after 2 gear adn in a lower rpm
Old Feb 10, 2006 | 09:08 PM
MidShipCivic's Avatar
Default Re: Please Help>>> How do I stop it??? (allmotoreglsvtec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by allmotoreglsvtec &raquo;</TD></TR><TR><TD CLASS="quote">try hitting it after 2 gear adn in a lower rpm</TD></TR></TABLE>
Are you sure about that lower rpm part?
Old Feb 10, 2006 | 09:30 PM
Default Re: Please Help>>> How do I stop it??? (MidShipCivic)
Hey guys,
Thanks for the replies. I have the nitrous set up to a toggle switch to engage and a full throttle microswitch to release the nitrous. At the track I come out of the lights on nitrous so in other words on nitrous right off the line. I backfired on the street. I accelerated in first off the nitrous, shifted to second and with the throttle at full position I engaged it releasing nitrous because I am at full throttle. It pulled hard until 7500-8000 rpm when it popped. I thought there she went!!! It idled like it was a V Twin Harley. It still had spark and compression so I guess it still had a weak pulse LOL. The last time it happened it was the map and sure enough it was the map again. This only happens on the street. No problems at the track.
Thanks
Old Feb 11, 2006 | 10:06 AM
Phase Change Racing's Avatar
A nitrous backfire at high rpm's is a pretty rare thing usually caused by hitting the rev-limiter, which i'd assume isn't the case here. A slightly burnt/bent exhaust valve could cause this or really screwed up valvetrain timing. Its not too uncommon to pop and fart out the exhasut with overly rich/lean combos, but to puke out the intake like that is a fairly rare thing indeed.
freaks_smk91
Dec 21, 2011 06:57 AM
traxxasx
Jun 25, 2009 12:12 PM
Royal_C!ty
Oct 28, 2005 11:25 AM
usdm420
Apr 29, 2004 12:02 PM
Duck Sauce
Dec 16, 2001 10:35 PM
