nitrous tapping into throttle body.
Old Jun 24, 2009 | 03:21 AM
traxxasx's Avatar
Default nitrous tapping into throttle body.
Ok i got a b16 and i installed the nitrous. I never had the fitting to tap into the intake pipe the right way and my rigged way has failed. So i was thinking can i tap the actuall throttle body right before the butterfly? Since its thicket and i can thread it to fit the nozzle for the nitrous. Has any1 done this before?
Old Jun 24, 2009 | 08:31 AM
Garage 808 Hatch's Avatar
Default Re: nitrous tapping into throttle body.
that is a bad idea. take your intake to a shop that can weld aluminum. have them weld a 1/4" thick aluminum block to it, so it can be drilled and tapped, and have enough material there to not strip out. have them drill and tap it for you. have it done 12-18" or so away from the TB. if you inject it in right at the TB, the pressure will most likely carry the mixture past runner 1 and maybe 2
Old Jun 25, 2009 | 12:12 PM
FST GSR 1's Avatar
Before anyone tells you where to put it, they should be asking if this is a wet or dry application. Also NOS sells a nice brass fitting for intake tubes to install the nozzle correctly PN#17283, 11$.
jksmith
16
Feb 6, 2009 07:08 AM
1lo95
Nov 30, 2004 04:14 AM
2SLO
Jan 28, 2002 04:46 AM
Duck Sauce
Dec 16, 2001 10:35 PM
stangkilla
Nov 1, 2001 07:50 PM
