please help gm 3 bar map info needed
Old 11-11-2006, 12:19 AM
ivt-t's Avatar
Default please help gm 3 bar map info needed
i just bought a hondata s300 but i cannot set it up for my 3 bar gm sensor.
any idea?
thank you
Old 11-11-2006, 12:50 AM
F20Cteg's Avatar
Default Re: please help gm 3 bar map info needed (ivt-t)
Click on the parameters button, then go to the MAP tab. Select replacement MAP sensor and select custom from the list, unless they finally added it in a new version of SManager. Then go t ohondata's web site and look up the parameters for the GM 3 BAR.
Easy as it comes.
Old 11-11-2006, 06:28 AM
ivt-t's Avatar
Default Re: please help gm 3 bar map info needed (F20Cteg)
will look,thank you
Old 11-11-2006, 07:47 AM
Redwidow's Avatar
use motec 3 bar
Old 11-12-2006, 11:21 PM
ivt-t's Avatar
Default Re: please help gm 3 bar map info needed (Redwidow)
will do
thank you
b18 hatch mike
08-29-2008 09:33 PM
h22sedan
12-03-2006 07:46 PM
turboeg77
02-26-2006 04:18 PM
Derek14
04-28-2004 09:18 AM
89civic1.8T
07-12-2002 11:22 AM
Quick Reply: please help gm 3 bar map info needed
