Please HElp Disaster.
Old Sep 29, 2002 | 06:22 PM
BoOsTeD_eK's Avatar
Default Please HElp Disaster.
Guys...I just finished an LS/Vtec build up for my friend and we drove around fine for about an hour or two...we got stuck in heavy traffic and it was stop and go....all of a sudden we started smelling anti freeze and popped the hood..the reservoir was bubbling so we shut off the car and let it cool down...as it was cooling down we heard some snapping/popping noises....???? But the car started up fine and nothign was wrong...so we are driving again and all of a sudden the temp gauge shoots up and the hood fills with white smoke. In the middle of the Tri Boro bridge. What happened...has anyone ever experienced this before...we used a cometic gasket if that helps. Now when we crank the motor..the coolant spits out the front of the engine right behind the header...from between the head and block union. Is the motor a gonner? ANy thoughts would be appreciated. Head was torqued down to 22ft- lbs and then to 63ft-lbs as the final sequence...Helms manual instructions were followed throughout.
[Modified by BoOsTeD_eK, 3:53 PM 9/30/2002]
Old Sep 29, 2002 | 06:25 PM
Jared's Avatar
Default Re: Please HElp Disaster. (BoOsTeD_eK)
Headgasket is killed. Is it on correctly? did you use any kind of sealant on the gasket? your best bet is to pull the head, clean everything out, drain the oil the best you can, get all the coolant out of the engine because its now contaminated, and start over with a new gasket and installation.
Old Sep 29, 2002 | 06:27 PM
BoOsTeD_eK's Avatar
Default Re: Please HElp Disaster. (Jared)
any thoughts on what CAUSED it?
Old Sep 29, 2002 | 06:31 PM
filetofit
Guest
Posts: n/a
Well ain't that a bitch. I'd suspect the head gasket too. You did remember to plug the Vtec oil galley in the head when you did the swap right?
Old Sep 29, 2002 | 06:41 PM
BoOsTeD_eK's Avatar
Default Re: Please HElp Disaster. (filetofit)
yes this was also done...I have done these freaking swaps about ten times...always used OEM gaskets..and this is my first time using Cometic...qanyone have bad experiences with Cometic?
Old Sep 29, 2002 | 06:45 PM
ekb18c's Avatar
Cometic hg's are usally good. You sure you got the correct headgasket? By the way, it's your headgasket that is gone. I ran into that problem before!
Old Sep 29, 2002 | 06:49 PM
FredoSP's Avatar
Well it sounds like the head gasket, BUT on my Grand Am, I had the same problem and it was a cracked cylinder head
Old Sep 29, 2002 | 07:43 PM
Sonny's Avatar
My guess is that you had air trapped in the head when you filled the system. Backfill next time to avoid this problem.
Sonny
Old Sep 30, 2002 | 01:53 AM
ion_four's Avatar
Default Re: Please HElp Disaster. (Sonny)
Sonny
How does one getrid of trapped air, exactly? (planning on swapping a ported head in a while)...
Old Sep 30, 2002 | 08:14 AM
BoOsTeD_eK's Avatar
Default Re: Please HElp Disaster. (ion_four)
sealant? I was suppose to use sealant on the headgasket? I have never ever done that in my life. Someone mentioned that the stock bolts might have backed out....could that have been the popping noises we were hearing when we turned off the car?
jimmypooh07
Nov 26, 2006 04:50 PM
Cyber ITR
Dec 8, 2005 11:57 PM
purple98ek
13
Sep 7, 2005 01:19 PM
Targa4Life
Aug 13, 2005 05:01 PM
BoOsTeD_eK
Sep 30, 2002 10:15 PM
