planning on turbo...question
Old Apr 7, 2004 | 10:44 AM
B18 CYA's Avatar
Default planning on turbo...question
ok so im planning to boost my b18c1 ...the quest ion i got is do i have to sleeve my block ? if its a stock sleeve do i have limitations as to how much psi i can have and whatnot? what would the advantage of having a sleeved block have over stock sleeve? Thanks
Old Apr 7, 2004 | 11:01 AM
FlaN.'s Avatar
you can boost on stock internals. I seriously suggest that you search before you post though
Old Apr 7, 2004 | 11:16 AM
B18 CYA's Avatar
no i am not boosting on stock internals...getting 9 to 1 comprssion je pistons and crower rods...its just sleeving that worries me....
Old Apr 7, 2004 | 11:21 AM
pgpunkguy's Avatar
Default Re: (c2nap)
how much do you plan on boosting?
i'm one who'd rather do it right and be safe... iron sleeves
but if you only plan to run modest boost (which i doubt) than stock sleeves should hold up ok...
Old Apr 7, 2004 | 11:40 AM
maskednegator's Avatar
Default Re: (pgpunkguy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pgpunkguy &raquo;</TD></TR><TR><TD CLASS="quote">
but if you only plan to run modest boost (which i doubt) than stock sleeves should hold up ok...</TD></TR></TABLE>
remember that intake manifold pressure doesn't break anything. if you're running 25psi, not detonating on the gas you're using, and only making 200whp, then you probably won't crack a sleeve. if, on the other hand, you're making 450hp at 12psi you run the risk of cracking a sleeve.
Old Apr 7, 2004 | 03:43 PM
bgsxyguy's Avatar
Default Re: planning on turbo...question (c2nap)
yea you can boost on stock internals just depends on what amount of boost you lookin for if ur goin 14 psi or higher u might want to
97grnrs
Jan 6, 2008 07:07 PM
CarAudioPro
Dec 6, 2005 09:37 PM
markvqwerty
Aug 27, 2004 03:59 PM
T3-T4TEG
Apr 21, 2004 04:01 PM
itr1236
Mar 10, 2002 05:18 PM
