place your blox manifold turbo enginebay pics here!
i wonder if i can fit the compressor facing the driverside of the car.
btw i have got a blox mani with a t3tO4E and a tial 38 on a b16a2 in a delsol.
All blox engine bay pics are welcome!!!!!!
Thanks!
Modified by dnbruut at 5:52 PM 11/17/2005
Thanks!
1 Post
Re: place your blox manifold turbo enginebay pics here! (dnbruut)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dnbruut »</TD></TR><TR><TD CLASS="quote">i wonder if i can fit the compressor can face the driverside of the car.
Thanks!</TD></TR></TABLE>
I have mine with the comp on the passenger side... I think you could do it the other way if your running a half rad.
I'll get some pics up later.
Re: place your blox manifold turbo enginebay pics here! (GS-R Civic)
do you think it will fit if you face the compressor side towards the driversside?
thanks!
all pics or thoughts are welcome!
thanks!
i actually think there is more room on that side, ill take a look later on to make sure tho...
im using a blox manifold i had to face my comp towards the driver side
because it did not fit facing the passenger side even after grinding off most of the webbing on the block im running a t3/04e 60ar housing it probaly fit if i had .50 ar housing.
Re: (randys)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by randys »</TD></TR><TR><TD CLASS="quote">the down pipe will not clear the radiator if you face the compresor to the drivers side</TD></TR></TABLE>
mine cleared with a 2.5 dp stock half size radiator and a slim fan it probaly won't clear if you have a fluidyne
Re: (LSTDB8)
1st marc thanks for the pics! wheres your fan? did you put it on the front of your radiator? any problems?
2nd randy yor saying that the downpipe wont fit because of the radiator. but if the radiator doesn't clear the downpipe than how is it going to clear the airfilter or intake pipe?
3rd lstdb8 i have a stock half style radiator with the stock fan, will it clear the downpipe(2.5inch) or do i need to/can i put the fan in front of the radiator? btw have you got any pics?
Thanks everyone!
keep the pics and thoughts comming!
Thanks everyone!
Re: (dnbruut)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dnbruut »</TD></TR><TR><TD CLASS="quote">1st marc thanks for the pics! wheres your fan? did you put it on the front of your radiator? any problems?</TD></TR></TABLE>
welcome. yeah the fan was a discount auto parts 12" fan. i had it before the blox setup from when I had my built sohc in there. i had no problems with that pusher fan setup or the turbo setup. having the fan on the front just made it easier to route the dumptube
Re: (dnbruut)
it should... but it will be tight, and i guarantee your dumbtube would have to be a lil funky, or use an elblow on the w/g.
race-lines.com
maybe i couldnt get it to work because i was trying to run a three inch down pipe. it was also a crx with a b16 swap. not much room for turbo to begin with.
Modified by randys at 2:00 PM 11/18/2005
Re: (randys)
Some good and some bad things to say about the blox manifold haha. Well I went to put it on today to make sure everything would fit alright and man was i in for a suprise.
i have a b18c in my 98 civic coupe, blox manifold and precision sc34 w/ .63 a/r ratio to clear things up. (compressor facing the passanger side)
first of all i had to cut the webbing on the block, most other people had to do that so i was like ok no big deal, then it still didn't fit. I had to grind more of the block away by the vin and engine code stamp. I eventually got it to fit after a lot of grinding.
Next prob.... wategate won't bolt directly onto the manifold, it hits the valve cover, and the elbow i was going to use won't work. No way my hood is going to close. So now i need a new elbow and a new dump
Other than the fittament issues the manifold looks pretty good, i can't wait to start boosting! I hope this helped anyone who was interested in this set up, you can pm me if you have any question
Re: (GS-R Civic)
right now im the only one makin downpipes for the blox manifolds . 2.5 ac. non ac. 3. inch non ac and ac avail. also wg elbows and dumptubes. my elbows fit well with the valve cover or ps bracket depending on what you order. of course mine are custom made to fit well however drag/other supplers are just giving drag universal elbows that of course doesnt fit very well and isnt in the correct position.
Re: (project dc2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by project dc2 »</TD></TR><TR><TD CLASS="quote">right now im the only one makin downpipes for the blox manifolds . 2.5 ac. non ac. 3. inch non ac and ac avail. also wg elbows and dumptubes. my elbows fit well with the valve cover or ps bracket depending on what you order. of course mine are custom made to fit well however drag/other supplers are just giving drag universal elbows that of course doesnt fit very well and isnt in the correct position. </TD></TR></TABLE>
oh yeah how can i forget the dp that you made for me
i had a spoolin perf 3" a/c dp for blox ... fit like a charm
