pistons and rods
Old Feb 6, 2009 | 06:26 AM
josh.p's Avatar
Default pistons and rods
hey, i have a teg with a b18b in it. im boosting it soon and just wanted to make sure if these are the pistons and rods i should be looking to get. im only boosting it low around 8 pounds and its my daily driver. heres the link. thanks in advance
http://cgi.ebay.com/ebaymotors/SRP-P...Q5fAccessories
Old Feb 6, 2009 | 06:35 AM
Garcia-Racing's Avatar
Default Re: pistons and rods
That seems a bit expensive. Camp 1320 has the rods for under $300, and those pistons are bout $330. I'd shop around.
Old Feb 6, 2009 | 06:45 AM
josh.p's Avatar
but am i going at the right derection ?
Old Feb 6, 2009 | 06:46 AM
Sure, eagle and srp will be fine.
Old Feb 6, 2009 | 06:50 AM
josh.p's Avatar
k thanks, and what kind of head gasket should i look for ?
Old Feb 6, 2009 | 07:16 AM
Thats opening a can of worms, but I run cometic. I don't have problems with them. Some will say only use stock or golden eagle. Any will work for you.
Old Feb 6, 2009 | 07:17 AM
josh.p's Avatar
cool. thanks for your help
Old Feb 6, 2009 | 10:55 AM
dpetro1's Avatar
you need to make sure you are getting the correct rods and pistons for the ls motor. that ebay ad lists multiple numbers for different compression and bore. you would want to go at least .25mm to .5mm over stock and something in the range of 9.0:1 - 9.5:1 compression for boost. and part# CRS5394A3D for rods
Old Feb 6, 2009 | 11:27 AM
SD_Lurker's Avatar
HT White Ops
Last I heard camp1320 bit the dust....
Old Feb 6, 2009 | 07:06 PM
No, I just talked to Thomas 2 days ago, still selling parts. As a matter of fact I'll be picking up a set of eagles from him next week.
Old Feb 6, 2009 | 07:08 PM
Why does he need to bore it over? Couldn't he just rehone the cylinders and slap a standard size in?
Old Feb 6, 2009 | 10:24 PM
civickiller's Avatar
isnt this speedclinc renamed?
Old Feb 6, 2009 | 10:32 PM
narfdanarf's Avatar
I don't know if speedclinic is the same as camp1320 or not, but speedclinic is out too now.
Old Feb 7, 2009 | 01:39 AM
Shaun Ek's Avatar
Yes he can rehone and use a standard size, 81mm to be exact. Thats what I did, running fine with no issues for over 6 months now.
Old Feb 7, 2009 | 09:46 AM
So have I, I was just wondering his reasoning behind it.
Old Feb 7, 2009 | 06:51 PM
K7-1Ktrevor's Avatar
Loved
Community Favorite
sometimes on an older motor std bore pistons will have excessive p2w clearance, usually it just results in piston slap but it can get worse as it goes on. Iv always been told to check to bore... then order the pistons... not the other way around.
Old Feb 7, 2009 | 09:41 PM
tegman23's Avatar
He can use standard bore, but be sure the block doesnt need bored..It may look ok to the eye but I would have a machine shop check it before you buy pistons...I normally buy oversized just so the block gets honed to the piston size and im done
Old Feb 8, 2009 | 08:59 AM
you mean bored?
Old Feb 9, 2009 | 08:32 PM
dpetro1's Avatar
i guess ive just always gone with the logic of getting a fresh bore and hone when redoing the bottom end. ive never actually built a bottom end so im no expert by any means.
is there any downside of going 10 or 20 over. besides having slightly thinner sleeves. what if the 81mm pistons were too small after honing?
Old Feb 10, 2009 | 06:53 AM
Honing doesn't take much material out, its just giving you a crosshatch pattern for oil retention and ring seal. He would have to bore it if the cylinders are tapered or out of round, but for a simple low milage setup a hone and stock bore should be fine.
Vagitarian
Sep 14, 2012 02:14 PM
young geezer
Oct 13, 2010 01:16 PM
Townson
Jan 7, 2009 08:43 PM
odishaw
Oct 17, 2007 09:17 AM
nota-ex
May 31, 2004 12:28 AM
