which pistons for nitrous
Old May 28, 2005 | 10:18 PM
elmo244's Avatar
Default which pistons for nitrous
i need some new pistons for my h22a.i had a nitrous puddle last time out at the track and cracked the number 2 piston.i'm not looking to bore it.thanks for any help.
Old May 28, 2005 | 11:05 PM
OMG B16's Avatar
Cp, Weisco, JE,ect... they all do the same thing...
Old May 29, 2005 | 12:32 AM
elmo244's Avatar
Default Re: (Sick00SiCoupe)
i was wanting to know what type of pistons, dish,dome,compression ratio ect.i think your supposed to go with dish type pistons wit a nitrous bluid up.
Old May 29, 2005 | 04:42 AM
CiViC SiR's Avatar
Default Re: (elmo244)
it all depands on ur tuner and i dont think dish type will help with nitrous
Old May 29, 2005 | 06:20 PM
randbcustoms's Avatar
Default Re: (CiViC SiR)
dish pistons lower compression ratio which will slow you down. if its a street car limit your compression ratio to 11 to 1 if you don't mind running 94 octane all the time or 10.5 to 1 if you wanna get by with 92 or 91. nitrous doen't affect compression ratio as with a turbo. the only thing to worry about is your cylinder pressure. forged pistons are obviously a must for any shot over 80. srp is a good street piston due to the 10 percent silicone in it allowing it to expand faster. je is the race piston and does not have any silicone in it. so it takes longer to expand but is stronger. assuming its a street car and u don't mind premium gas.. srp pistons with an 11 to 1 ratio works perfectly..
Old May 30, 2005 | 11:17 AM
elmo244's Avatar
Default Re: (randbcustoms)
thank you
Old May 30, 2005 | 12:07 PM
_entropy's Avatar
Need to sleeve it to use aftermarket pistons champ.
Old May 30, 2005 | 12:57 PM
aj99si's Avatar
Default Re: (Napoleon Dynamite)
mahle makes forged pistons for stock h22a sleeves. They are the only ones I know of.
vtechjunkie
Sep 22, 2009 03:41 PM
Dr.Honda
Apr 19, 2007 12:29 AM
lsvtechatch92
May 10, 2006 09:53 PM
HarryB
Jun 19, 2002 04:56 PM
96tegsr
Nov 8, 2001 02:38 PM
