which pistons to buy
Old Oct 14, 2007 | 12:13 PM
anton_'s Avatar
Default which pistons to buy
which pistons should i buy for my b16a1 turbo?
i broke my cp pistions because of a bad tune.
i bought a new block in good condition 81mm. should i buy 81 or 81,5mm pistons?
what brand should i buy?
just shooting for 340whp
can you recomend any good seller?
Old Oct 14, 2007 | 12:17 PM
doood's Avatar
been there done that
Default Re: which pistons to buy (anton_)
je
cp
wiseco
arias
endyn
they all make good pistons. it's personal preference. you can do 81.5mm so you have a fresh cylinder to start with.
Old Oct 14, 2007 | 07:40 PM
HiProfile's Avatar
If you broke CP's your fucked. Totally fucked. They are the absolute pinicle of awsomeness and are stronger than a 100% pure alloy block of awsomeness. At least thats what you'll hear from the tuners that use them exclusively. No **** a tuner that has done MANY cars won't care about a part thats only excessively 'fragile' when not treated properly. When you don't tune it yourself, don't have a way to check cylinder pressure, don't have a few thousand wraped up in an individual cylinder detonation system...<U>you don't want something that will break when the slightest thing goes wrong.</U>
I'd suggest Wisecos. Good pistons, good prices, good phone support (you get someone from the USA!). I recall seeing a big compair-o, and Wiseco was #2 behind some other piston in terms of the skirt's taper, as well as consistency between pistons. That and a lot of people here have had good luck with them. Even with a crap tune.
Old Oct 14, 2007 | 09:26 PM
tony413's Avatar
wiseco's 82mm if you get sleeves an drop that compression to 8.5:1 and crank up the boost on pump gas
Old Oct 14, 2007 | 11:34 PM
anton_'s Avatar
Default Re: (tony413)
if one of the pistons will brake, can i buy just one pistons from all of these brands?
Old Oct 15, 2007 | 08:17 AM
tony413's Avatar
i dont see why not you would need to contact the manufacture for the replacement though
Old Oct 15, 2007 | 08:46 AM
Topdawgg's Avatar
take the block in to a machine shop, see what bore it has to be taken to... (the size of the most out of round cylinder)
order pistons for that size... take pistons into machine shop before they do the final bore...
cp, arias, wiseco, JE.... any of those are fine...
/thread
Old Oct 16, 2007 | 01:31 AM
anton_'s Avatar
Default Re: (Topdawgg)
what does a sleeved block cost?
Old Oct 16, 2007 | 06:39 AM
Topdawgg's Avatar
850 from golden eagle...
you gotta supply the block for that price.. and ship it there
Old Oct 16, 2007 | 06:55 AM
twkdCD595's Avatar
Default Re: which pistons to buy (HiProfile)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HiProfile &raquo;</TD></TR><TR><TD CLASS="quote">If you broke CP's your fucked. Totally fucked. They are the absolute pinicle of awsomeness and are stronger than a 100% pure alloy block of awsomeness. At least thats what you'll hear from the tuners that use them exclusively. No **** a tuner that has done MANY cars won't care about a part thats only excessively 'fragile' when not treated properly. When you don't tune it yourself, don't have a way to check cylinder pressure, don't have a few thousand wraped up in an individual cylinder detonation system...<U>you don't want something that will break when the slightest thing goes wrong.</U>
I'd suggest Wisecos. Good pistons, good prices, good phone support (you get someone from the USA!). I recall seeing a big compair-o, and Wiseco was #2 behind some other piston in terms of the skirt's taper, as well as consistency between pistons. That and a lot of people here have had good luck with them. Even with a crap tune. </TD></TR></TABLE>
wisecos sound like they are a replacement for needing any quality tuning... thats sweet, I mean who REALLY needs a tune anyways... just buy wiseco pistons and pull the vac line off the wastegate. I bet they must also be using some of that pinicle of awesomeness and stronger than 100% pure alloy block of awesomeness you speak of, like ubertanium or something...
as said above by others... there are many good piston manufacturers, its personal preference... you can find issues with many pistons... not just cp by any means and they are mostly due to very tight clearances, tuning issues, etc.
like the destroyed wiseco pistons thread on page 2 currently.
Modified by twkdCD595 at 10:10 AM 10/16/2007
Old Oct 16, 2007 | 08:01 AM
DC2_117's Avatar
Default Re: which pistons to buy (doood)
CP
JE
Endyn (I like them more for n/a though, roller wave)
Old Oct 16, 2007 | 08:19 AM
BoostedJeff's Avatar
Default Re: which pistons to buy (DC2_117)
Wiseco
Old Oct 17, 2007 | 12:41 AM
anton_'s Avatar
Default Re: which pistons to buy (BoostedJeff)
thanks.
can someone recommend a piston dealer?
it,s sad that its so expensive to ship a block, but i have the hole winter to save money
Old Oct 17, 2007 | 03:35 AM
N20civicB18's Avatar
Contact Terry @ Boostfed or James @ IPG
tfalconier
15
Mar 24, 2013 03:58 PM
JDMotive
May 28, 2004 02:26 PM
c1civic
Jan 18, 2004 07:11 AM
Mr. Softee
Jul 27, 2003 10:26 PM
Monty
Nov 29, 2002 10:56 PM
