CP pistons
Old May 10, 2007 | 07:25 PM
litovi3tboi503's Avatar
Default CP pistons
I got 85mm cp pistons my friend measure it out to be 84.95 mm. Does CP piston make their piston a little smaller? My bore now is 85.04 mm. Will this work out or am i screw? How much do CP piston expand? I will have to wait to call CP tomorrow as well to make sure any info will help guys thanks.
Old May 10, 2007 | 08:07 PM
riceburner700's Avatar
Default Re: CP pistons (litovi3tboi503)
i am 98% sure CP doesn't make a piston out of spec
Old May 10, 2007 | 08:10 PM
Default Re: CP pistons (riceburner700)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by riceburner700 &raquo;</TD></TR><TR><TD CLASS="quote">i am 98% sure CP doesn't make a piston out of spec</TD></TR></TABLE>
do they make it 84.95 because its not including the rings?
Old May 10, 2007 | 08:52 PM
WalkerGSR1's Avatar
Where was the piston measured at? Did your friend measure it at the piston skirt?
Old May 10, 2007 | 09:09 PM
Muckman's Avatar
Moderator in Chief
The piston to wall clearance is built into the piston. Meaning it is smaller than the spec. ie - if your using an 84mm CP piston, you have your cylinders bored to 84.00mm exactly.
Modified by Muckman at 10:22 PM 5/11/2007
Old May 11, 2007 | 09:12 AM
Default Re: (WalkerGSR1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by WalkerGSR1 &raquo;</TD></TR><TR><TD CLASS="quote">Where was the piston measured at? Did your friend measure it at the piston skirt?</TD></TR></TABLE>
yup
Well right now im about .05mm over. I was informed that CP piston makes their piston to wall clearance already into the piston. So the piston size is actually 84.9mm and the .1 gone is the piston to wall clearance which is about .0035". So 85mm piston for exactly 85mm bore. I Guess ima have to go piston skirt coat with swaintech. Have anyone ever use this company before? I called CP today and they told me to go that route. Hopefully everything works out.
ZCHondaCRX91
Engine Machining & Assembly
Feb 12, 2019 02:43 AM
ziurek filmus
Apr 16, 2017 10:17 PM
black99x
Aug 11, 2006 07:40 AM
Ri5e
Aug 7, 2002 08:31 PM
supergreenNA1
Mar 24, 2002 02:19 AM
