piston rings mite be blown plz help...
Old Nov 3, 2004 | 08:40 PM
hitvtecgetloud09's Avatar
Default piston rings mite be blown plz help...
i just recently turboed my 99 si, and i am blowing out some steam from the hose that comes out my valve cover, i was told it could be my pistons rings, and b4 i went turbo every time i would hit vtec in 1st gear i would see a puff of white smoke threw my exhaust but only in first gear.. could this be my pistons rings or something else..
Old Nov 3, 2004 | 08:47 PM
SpeedingHatch's Avatar
Default Re: piston rings mite be blown plz help... (hitvtecgetloud09)
usually thats blow-by
Old Nov 3, 2004 | 08:59 PM
JET_dC4's Avatar
Default Re: piston rings mite be blown plz help... (SpeedingHatch)
you know all about blow by now dont you
Old Nov 3, 2004 | 10:25 PM
Default Re: piston rings mite be blown plz help... (JET_dC4)
i have NO idea wat blow-by is lol heard of it never found out wat it is
Old Nov 4, 2004 | 05:12 AM
DropNotch's Avatar
It could be your rings or the ringslands that hold the rings.
Recently i had to rebuild my motor because of both of these. I had white smoke that was visible coming out of that little line coming out of the valve cover anytime the throttle was pressed at all. Also there was a noticable change in the exhaust sound. Kinda sounded like a four wheeler. I didnt have any smoke out the exhaust though, if you have alot of that it generally means headgasket.
in my opinion your rings might be either going bad or are already bad. You can have it checked through a compression check of the cylinders. Money willing if they are bad, or going bad, it wouldnt hurt to just replace them with forged pistons and rods.
Basically if you plan to replace them might as well do the following as well while you have the motor apart.
Rings
Pistons/rods (forged or Oem if they are damaged)
Rod bearings
Main bearings
Head gasket
Timing belt
Water pump
and have the cylinders honed out.
thats basically a lite rebuild and shouldnt cost too much.
Old Nov 4, 2004 | 07:35 AM
B18EG6's Avatar
Default Re: piston rings mite be blown plz help... (DropNotch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DropNotch &raquo;</TD></TR><TR><TD CLASS="quote">Rings
Rod bearings
Main bearings
Head gasket
Timing belt
Water pump
thats basically a lite rebuild and shouldnt cost too much.</TD></TR></TABLE>
**** man... define 'too much'
To the originator of this post.- it would greatly help you to do a leakdown test, or have one done. That will help pinpoint your problem and tell you a lot more.
If you want to know how to do one, feel free to IM me.
Old Nov 4, 2004 | 07:45 AM
1Bar GSR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SpeedingHatch &raquo;</TD></TR><TR><TD CLASS="quote">usually thats blow-by</TD></TR></TABLE>
Sounds like blow-by there have been similar cases on here with the same diagnosis.
Old Nov 4, 2004 | 08:56 AM
PrettyLude's Avatar
piston rings are worn or shot
boom32
Jun 5, 2008 04:28 PM
1bar_ek
Apr 17, 2007 10:00 AM
ricemaster (r)
Jun 3, 2003 09:19 PM
SymphonyX
Mar 18, 2003 09:52 PM
