Piston Help!!!!!
Old Nov 18, 2010 | 03:12 PM
roudiiboii's Avatar
Default Piston Help!!!!!
Ok so i have a turbonetics t3/t4 turbo, skunk2 pro cams and gears, and complete supertech valve train on my gsr but here is the thing i am boring the block and using 82mm low compression forged pistons. what kind of Pistons should i purchase and will the walls be too thin if i use 82mm pistons? Please help me if any one has any info on this
Old Nov 18, 2010 | 06:57 PM
ryguy2588's Avatar
Default Re: Piston Help!!!!!
Personally, if you're gonna boost, I wouldn't go over a 81.50mm bore otherwise get your block sleeved. Wall thickness doesn't really determine what pistons you should get. I'm running some Supertech 81.50mm 9.0:1 pistons. They're forged, they're the same pistons a Mahle supposedly, and they only cost $380 with pins and rings!
Old Nov 19, 2010 | 09:30 AM
roudiiboii's Avatar
Thanks for your help man. im going to have to sleeve the block but now i dont know how big of a piston to get and ideas?
Old Nov 19, 2010 | 08:47 PM
dancing_ninja's Avatar
What kind of motor? Stock sleeves or aftermarket? 9.0:1 is the absolute lowest I would go.
Old Nov 20, 2010 | 06:05 AM
ryguy2588's Avatar
Since you're gonna sleeve it, use darton sleeves and send it to a vendor who can do the sleeving for you. They have sleeves at different sizes or you can bore the sleeves out to the size you want. The bigger the bore, the more torque! If you really wanna go big, just get the 84mm bore size and some 84mm pistons to match it and you'll be puttin a ton of torque down. dancing_ninja is right. Don't go below 9.0:1 because anything below that is gonna be compression for a track car that's gonna be making 600+whp with 30+psi of boost. I know supertech has a 9/9.1/9.5:1 pistons from
http://www.jhpusa.com/store/pc/viewP...idproduct=3010
You can choose the compression and the bore size you want, and they're only $390!!!!
Old Nov 20, 2010 | 09:41 AM
roudiiboii's Avatar
see here is the thing my machinists scratched a stock sleeve and what I think I am going to do rather than sleeving it I'm just buying a new short block and boring it 81.5 with supertech 9:1 pistons would this be better?
Old Nov 20, 2010 | 09:54 AM
Golden Eagle's Avatar
I would go 84mm with Arias racing pistons 9.5:1 and Eagle H beam rods.
Coast to coast G.E. engine sleeves let you boost the most.
We wont sink your ship or your sleeves.
Go Big power with G.E. and fly like an eagle.
Sleeve service includes step decking.
Our sleeve design is like having four block guards stacked.
G.E. will help you get off the porch and run with the big dogs.
PM for pricing.
Old Nov 20, 2010 | 10:17 AM
We and most other racers run considerably higher compression than 9.0. You actually want to run higher pending what kind of gas you'll be running. For a street car 9.5 to 10 is very efficient. I believe there is a misconception of having to run lower compression. Especially for Hondas.
Old Nov 20, 2010 | 12:22 PM
ryguy2588's Avatar
If you're gonna buy a new short block, I wouldn't even bore it then. Keep the sleeves as thick as possible. I only needed to bore mine to 81.5mm because I wanted my pistons to have the perfect clearance and a hone would've made it just too wide because its been honed before. If there's no need to bore, then don't. Hone it and leave it at 81mm. Sleeving is pretty expensive, and honda sleeves in a gsr are pretty strong as long as you aren't running too much boost and you have a good tuner.
Old Nov 20, 2010 | 03:36 PM
b18master's Avatar
arias pistons are the best, with stock sleeves go 81mm, for aftermarket sleeves go for 81mm too so if you damage a sleeve you can bore it again and again and again...
bigger bore doesn't make that much difference...
Old Nov 21, 2010 | 04:45 PM
roudiiboii's Avatar
so should i go with stock bore 9.5:1then? its being daily driven im not going full blown race car just to get me from point a to point b much much faster
Old Nov 21, 2010 | 04:51 PM
93egSLEEPER's Avatar
PM for pricing.
Your block might be junk afterwards too...or need an align hone for $300+. Check out laskey racing and benson sleeves. GREAT SHOP!
hoffmanb16
30
Oct 30, 2017 03:41 AM
LS-turboner
Dec 31, 2009 01:13 PM
methos713
21
Jun 14, 2007 10:56 PM
5thgencivic
Nov 29, 2003 03:26 PM
MisterB
Jan 15, 2002 11:26 AM
