Picture Request....
Old Feb 4, 2007 | 11:49 AM
  #126
h22sedan's Avatar
Default Re: (B18Sleeper)
Just curious, what is that bracketed object next the the exhaust cam gear? The thing that looks like a throttle cable. I've seen them on a few turbo cars and I have no clue what it is or what it does.
Old Feb 4, 2007 | 12:03 PM
  #127
B18Sleeper's Avatar
Default Re: (h22sedan)
good question i haven't seen that before
Old Feb 4, 2007 | 12:04 PM
  #128
turboedc2's Avatar
ITS A CAM TRIGGER KIT HERES SOME INFO FROM T1'S WEBSITE...
The use of this kit allows you to change from the factory honda mag sensors in the distributor to a more precise digital signal from this sensor. Many aftermarket ecus read the Hall signal much better than they do the oem signal from the distributor. A lot of times you'll notice a smoother idle & much smoother power at high rpm. This also allows complete removal of the factory distributor when a multi channel CDI box & individual coils are used with it. If you want to keep a single channel ignition box & the distributor, then this setup can still be used. These signals are on the input side of the ecu, while the ignition system is on the output. Any combination of ignition box/coils will work.
The standard kit consists of 1 Golden Eagle cam gear that's been machined & custom fit with rare earth magnets installed in it, 1 Dual Pole hall sensor & it's mating conncector, the billet sensor bracket, & installation instructions.
Old Feb 4, 2007 | 12:07 PM
  #129
B18Sleeper's Avatar
Default Re: (turboedc2)
so the only benefits is smoother idle at high rpms and removal of distrubitor? is that really worth it ......
Old Feb 4, 2007 | 12:44 PM
  #130
Soccerking3000's Avatar
smoother idle, and you'll have less breaking up at higher rpm, its a much better system than the stock ecu for high horsepower engines. It's definitely worth it
Old Feb 4, 2007 | 12:48 PM
  #131
B18Sleeper's Avatar
Default Re: (Soccerking3000)
what is consider higher hp cars?
Old Feb 4, 2007 | 12:49 PM
  #132
500+
Old Feb 4, 2007 | 12:56 PM
  #133
B18Sleeper's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Soccerking3000 &raquo;</TD></TR><TR><TD CLASS="quote">500+</TD></TR></TABLE>
i will never be that high so i dont have to worry about it lol
Old Feb 4, 2007 | 01:18 PM
  #134
zexxbo's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18Sleeper &raquo;</TD></TR><TR><TD CLASS="quote">i will never be that high so i dont have to worry about it lol</TD></TR></TABLE>
thats what you say now.
Old Feb 4, 2007 | 01:39 PM
  #135
Default Re: (zeimbo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by zeimbo &raquo;</TD></TR><TR><TD CLASS="quote">
thats what you say now. </TD></TR></TABLE>
i man never spoke truer words, i thought i'd be happy with a stock z6 with a greddy kit, next thing you know i have a sleeved block and its fully built and i want 500 lol
Old Feb 4, 2007 | 01:56 PM
  #136
B18Sleeper's Avatar
i man never spoke truer words, i thought i'd be happy with a stock z6 with a greddy kit, next thing you know i have a sleeved block and its fully built and i want 500 lol</TD></TR></TABLE>
yea but what u all dont understand is that when u get in 500hp ranges its a mostly drag car and i dont want that...i want to be able to drive this on the road and not have problems with it. i dont want a car i can only handle at the track. or someting i have to cage it. if i build my si and want more power i will build another car and cage it and make ita drag car but i really dont see me goin over 500hp in my si
Old Feb 4, 2007 | 04:25 PM
  #137
cuin9sec
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18Sleeper &raquo;</TD></TR><TR><TD CLASS="quote">what is consider higher hp cars? </TD></TR></TABLE>
man youre just full of questions huh! lolz....just messing with ya man.
Old Feb 4, 2007 | 04:34 PM
  #138
B18Sleeper's Avatar
Default Re: (cuin9sec)
there is no such thing as a dumb question man lol....and if i got a question i want the answer cause how else do u learn any of this **** lol....
Old Feb 4, 2007 | 04:36 PM
  #139
well ask away most of us aren't ******** lol. But yea 500hp is fun even on the street well the freeway lol
Old Feb 4, 2007 | 04:58 PM
  #140
zexxbo's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18Sleeper &raquo;</TD></TR><TR><TD CLASS="quote">yea but what u all dont understand is that when u get in 500hp ranges its a mostly drag car and i dont want that...i want to be able to drive this on the road and not have problems with it. i dont want a car i can only handle at the track. or someting i have to cage it. if i build my si and want more power i will build another car and cage it and make ita drag car but i really dont see me goin over 500hp in my si </TD></TR></TABLE>
you can make 500whp daily driven and reliable. it all depends on your parts, your tune, your driving and your maintenance. of you can get a boost controller that scrambles. so at the hit of a button, it will scramble to 20lbs or whatever you set it to, and youll get that 500+ hp for 30 seconds and then it goes back to your setting for daily driving.
Old Feb 4, 2007 | 05:00 PM
  #141
allricedout's Avatar
nice thread so far...... any pics of e-bay turbo kits? i know ive seen some charge piping so far............BUMP
Old Feb 4, 2007 | 05:57 PM
  #142
B18Sleeper's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by zeimbo &raquo;</TD></TR><TR><TD CLASS="quote">you can make 500whp daily driven and reliable. it all depends on your parts, your tune, your driving and your maintenance. of you can get a boost controller that scrambles. so at the hit of a button, it will scramble to 20lbs or whatever you set it to, and youll get that 500+ hp for 30 seconds and then it goes back to your setting for daily driving.</TD></TR></TABLE>
yes i know 500hp can be reliable and daily driver but i live in a city with a lot of stop and go driving...and 500hp aint built for that. i dont drive interstates and freeways everyday or it would be another option. i did think about saving 2 tunes one for around 300 and another for 500+ but i think that is to much for right now. and why would u just want 500+ for 30 seconds?
Old Feb 4, 2007 | 06:00 PM
  #143
zexxbo's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18Sleeper &raquo;</TD></TR><TR><TD CLASS="quote">yes i know 500hp can be reliable and daily driver but i live in a city with a lot of stop and go driving...and 500hp aint built for that. i dont drive interstates and freeways everyday or it would be another option. i did think about saving 2 tunes one for around 300 and another for 500+ but i think that is to much for right now. and why would u just want 500+ for 30 seconds? </TD></TR></TABLE>
lol, well have any of your races ever lasted longer than 30 seconds? especially when youre putting down 500whp, youre gonna be flying by and youll be lucky if they last more than 5 seconds. even with stop and go driving, that doesnt mean anything. if you have a turbo capable of 500whp, its not going to spool until 4000rpm or so, that means that you can daily drive it without hitting boost if you wanted to.
Old Feb 4, 2007 | 06:13 PM
  #144
Tchleung's Avatar
What alot of people seem to not understand is, a 500hp TURBO car is nothing like a hardly idling 500hp NA car. You can make 1000 hp and still be able to drive it around just fine. Good luck doing that with a NA car.
Old Feb 4, 2007 | 06:30 PM
  #145
B18Sleeper's Avatar
Default Re: (Tchleung)
yea but with cars those high of numbers dont u have to put roll cages in them? i am not doing this to my car.
Old Feb 4, 2007 | 06:34 PM
  #146
D-meet07's Avatar
Heres my month old kit that I put together. The rust on the hot pipe is gone. Painted it over black and my dump tube has already been fabed up. I put the radiator fan back on
theres my bling manifold...
Old Feb 4, 2007 | 06:39 PM
  #147
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18Sleeper &raquo;</TD></TR><TR><TD CLASS="quote">yea but with cars those high of numbers dont u have to put roll cages in them? i am not doing this to my car. </TD></TR></TABLE>
no cages are just needed if you run a 11.99 or faster i think you could have 124135135hp and run a 12.01 and not need a cage
Old Feb 4, 2007 | 06:43 PM
  #148
civicjdmb16a's Avatar
Old Feb 4, 2007 | 06:50 PM
  #149
B18Sleeper's Avatar
Default Re: (civicjdmb16a)
clean motors love the setups....keep them coming
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Soccerking3000 &raquo;</TD></TR><TR><TD CLASS="quote">no cages are just needed if you run a 11.99 or faster i think you could have 124135135hp and run a 12.01 and not need a cage</TD></TR></TABLE>
and what does 500hp motors usually run at the track ?
Old Feb 4, 2007 | 07:03 PM
  #150
well i had 432whp and ran 11.3 on slicks...
