pics of check valves
Old Jun 2, 2002 | 01:26 PM
integraracer94's Avatar
Default pics of check valves
My missing link isn't doing much so i am going to try the check valve setup, but I am unsure how to actually connect the valves to the intake manifold. The MAP sensor has a perfect place to hook up a hose but the intake manifold has nothing.
it is on a 94 integra LS
tried to do a search but didnt find anything
Old Jun 2, 2002 | 02:00 PM
inspyral's Avatar
Default Re: pics of check valves (integraracer94)
Get some vac hose and some tees, and hook up your check valves so they look like this(horizontal lines are vac hose, vertical lines are check valves, tees are at the intersections):
___|__|__|___
Then, plug one end of your completed assembly into the bottom of your MAP sensor, then put a 90 degree elbow on the other side and jam it into the hole on top of the throttle body where the Map sensor used to sit. You may have yo use some silicone or something to keep it in place, since they like to pop off under boost.
Old Jun 2, 2002 | 04:35 PM
Hybrid's Avatar
Default Re: pics of check valves (inspyral)
Use a brake check valve and you won't have a problem.
Old Jun 2, 2002 | 04:38 PM
AbaZ's Avatar
their..
Jeff
[Modified by AbaZ, 1:39 AM 6/3/2002]
Old Jun 2, 2002 | 04:42 PM
Hybrid's Avatar
Default Re: pics of check valves (AbaZ)
Much easier and cleaner to use a brake check valve.
You'll see pics Jeff when I send my info for your site.
Old Jun 2, 2002 | 06:03 PM
inspyral's Avatar
Default Re: pics of check valves (Hybrid)
like a speedbleeder?
Old Jun 2, 2002 | 06:34 PM
thanks guys
wanttorace
Jun 11, 2003 06:55 AM
Integra_Boi
Aug 11, 2002 07:03 PM
turbotec
Feb 26, 2002 03:34 PM
Rob03Pro5
Jul 25, 2001 08:37 PM
