intercooler piping touching downpipe.
Old Oct 20, 2006 | 09:20 PM
Project99EK's Avatar
Default intercooler piping touching downpipe.
hey everyone just wanted to make sure its ok if the intercooler piping touching the downpipe is ok, or if it affects anything? thanks again
Old Oct 20, 2006 | 09:24 PM
SoSlo's Avatar
Default Re: intercooler piping touching downpipe. (Project99EK)
this will lead to heating up your intake air temp which will lead to less hp and ealier detonation if it gets too hot, it will also rattle like a bitch
Old Oct 20, 2006 | 09:25 PM
B.'s Avatar
B.
400 HP Club
Default Re: intercooler piping touching downpipe. (SoSlo)
why does it come so close?
Old Oct 21, 2006 | 02:13 AM
Default Re: intercooler piping touching downpipe. (B.)
its an a/c setup, so the intercooler piping passes under the downpipe. but in my case the moron who made my downpipe didnt pull it close enough to the block so it is in the way of the intercooler piping route so i just pushed it up against the dp to make it fit.
Old Oct 21, 2006 | 03:59 AM
Lordie's Avatar
use heat wrap to separate heat.
Old Oct 21, 2006 | 06:57 AM
banmeagain's Avatar
Default Re: intercooler piping touching downpipe. (Lordie)
its fine, my dp is touching both my rad and ic piping, contrary to logic, no heat is really transferred
Old Oct 21, 2006 | 08:08 PM
Default Re: intercooler piping touching downpipe. (banmeagain)
Can anyone else confirm this? thanks again
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by banmeagain &raquo;</TD></TR><TR><TD CLASS="quote">its fine, my dp is touching both my rad and ic piping, contrary to logic, no heat is really transferred</TD></TR></TABLE>
Old Oct 21, 2006 | 09:55 PM
not2slo128's Avatar
U don't want ur DP touching ur IC piping. (= Hack)
Old Oct 22, 2006 | 07:14 AM
Default Re: intercooler piping touching downpipe. (not2slo128)
i would love to change it, if you would pay the money to fix whats wrong with it, since i already payed for the manifold and downpipe to fit like **** Anyways What if i heatwrap the DP?
Old Oct 22, 2006 | 10:46 AM
vtec.dc2's Avatar
theres always ways around it.. if you're using aftermarket fans, you radiator may have some brackets that could be trimmed, you maybe able to extend the pipe or change the direction of one of the pipes a bit. i'm dealing with same issue. radiator vs a/c line vs IC pipng vs DP all in same spot. but some cutting and adjustements none of them touch but i still have very little clearance.
Old Oct 22, 2006 | 10:57 AM
rickturboteg's Avatar
Default Re: intercooler piping touching downpipe. (vtec.dc2)
i had the same problem with my integra..didnt really transfer that much heat but then again its not good...be on the safe side and get that downpipe redone and make it closer to the block
SkyliteCustomz
Jan 14, 2010 01:44 PM
93_teg_CT
Jun 2, 2006 11:51 PM
corey's96GSR
May 1, 2004 11:06 AM
Soon_2b_evil
Oct 12, 2003 03:04 PM
