PCV system trouble...please help
Old May 20, 2004 | 09:07 PM
Rod.'s Avatar
Default PCV system trouble...please help
Where do I put this pcv system. I took it off my 95 ls block, but I am building a 96 block. THere are no holes for this to fit in like the old block
Old May 20, 2004 | 09:33 PM
98gsrTEG's Avatar
Default Re: PCV system trouble...please help (redturbocivic)
the obd2 ls blocks have the pcv valve feeding off of the valve cover. so you will need to prolly get a 96+ls valve cover.
Old May 20, 2004 | 09:37 PM
Rod.'s Avatar
Default Re: PCV system trouble...please help (98gsrTEG)
I forgot to say i am going to run a b16 head. How do I get around that?
Old May 20, 2004 | 09:49 PM
Kwuaymaikrup's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by redturbocivic &raquo;</TD></TR><TR><TD CLASS="quote">
Just plug this one.
Old May 20, 2004 | 09:54 PM
Rod.'s Avatar
Default Re: PCV system trouble...please help (Kwuaymaikrup)
I just now notice I can not even use the black box on my 96 block. The holes are plugged. Can I run with out a pcv system on my motor or hook a catch can up and call it a day????? thanks
Old May 20, 2004 | 09:55 PM
98gsrTEG's Avatar
thats his old motor. his new one that he is building does not have the hole in it. you may need to make a hole for it since thats were the b16 pcv sits. and it may be kinda hard to do it in the valve covver
Old May 20, 2004 | 10:11 PM
Rod.'s Avatar
dang, that is going to be some major work. There has to be a way around it. Can you just run a catch can or that is out of the question??
Old May 20, 2004 | 10:49 PM
98gsrTEG's Avatar
you need a pcv valve, so you can't really just run a catch can.
Old May 21, 2004 | 04:19 AM
Tony the Tiger's Avatar
If you are running a catchcan setup with drain back, you will have to bust a new hole there.
Old May 21, 2004 | 07:59 AM
Alchemist's Avatar
You can run the endyn system and then you wont need that black box at all.
Old May 21, 2004 | 04:17 PM
Rod.'s Avatar
Default Re: (Alchemist)
Thanks everyone for you help. I just picked a endyne catch can kit today and hope to install it tonight
Old May 22, 2004 | 06:36 AM
B18C1CYA's Avatar
Default Re: (redturbocivic)
catch can is the better way to go if your fi
HandMadeEgRHd
May 8, 2010 06:29 PM
djtsmith007
Apr 23, 2007 08:29 PM
freakasis
Jul 5, 2005 02:32 PM
sander
Mar 16, 2003 08:23 PM
InfamousRS
Oct 8, 2002 07:36 AM
