Partial-throttle tuning with uberdata?
Old Aug 31, 2005 | 07:06 AM
  #26
BlueShadow's Avatar
Default Re: Partial-throttle tuning with uberdata? (boostincoupe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostincoupe &raquo;</TD></TR><TR><TD CLASS="quote">&lt;---- h3lla confused on the difference between open and closed loop. I just want my car to run smooth and be fast! </TD></TR></TABLE>
IIRC open loop is when the engine is running entirely off of the fuel maps on the ECU. Some examples of when your car is in open loop is if you are WOT, or if you have closed loop disabled through Uberdata or Crome. When you are in closed loop your O2 sensor readings going to the ECU cause the engine to make slight fuel changes. An example of closed loop operation is when you are at idle or cruising conditions. If you disable closed loop then at idle and cruising the O2 sensor doesn't correct fuel.
I believe that's how it goes.
EDIT: I think when you are tuning people usually disable closed loop (put it in open loop). Then once they have their AFR's where they want them they enable closed loop.
Old Aug 31, 2005 | 07:17 AM
  #27
Pikachu's Avatar
Can uberdata idle 1000cc injectors? I'm just curious if it can do that.
Old Aug 31, 2005 | 07:30 AM
  #28
93turbo16's Avatar
Default Re: (Pikachu)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Pikachu &raquo;</TD></TR><TR><TD CLASS="quote">Can uberdata idle 1000cc injectors? I'm just curious if it can do that.</TD></TR></TABLE>
Yes it can do it. The fuel modifiers are being worked on right now, and that will make it even easier to do.
Old Aug 31, 2005 | 07:49 AM
  #29
boosted k20's Avatar
Default Re: (93turbo16)
people have idled 1000cc before. im gonna experiment with a set of 1600cc injectors. i dont know how successful i'll get with those. might have to step down to 1000cc
Old Sep 3, 2005 | 01:42 PM
  #30
scttydb411's Avatar
i haven't had problem partial throttle tuning uberdata. tune partial trottle ranges by columns and then wot by rows. works every time and no need to data log if you don't have it.
Old Sep 3, 2005 | 01:54 PM
  #31
2k.civic.si's Avatar
Default Re: (scttydb411)
crome + rtp + autotune = easy fuel map tuning....i wouldnt waste my time with anything else....
my ecu for tuning
bluenc-87
Engine Management and Tuning
Aug 22, 2015 01:53 AM
blackeg
Aug 19, 2013 05:30 PM
DeucesGoneWild
12
Feb 22, 2010 10:02 PM
connor53
May 26, 2008 10:29 PM
