Paintball tank nitrous?
Old Nov 20, 2005 | 08:20 PM
NACvicSi's Avatar
Default Paintball tank nitrous?
I know I am going to catch major flame for this. Anyways, I have a couple of 20oz paintball tanks that I don't use anymore. If I had a solenoid, nozzle, other minor crap, would I be able to use this as nitrous. Like shooting a 35 shot? Would probably be used more as a intercooler spray, just interested if it would work.
Also about how many shots of 35 would I get out of a little 20oz bottle.
Old Nov 20, 2005 | 08:43 PM
bluemax189's Avatar
Default Re: Paintball tank nitrous? (NACvicSi)
co2 paintball tanks and the paintball nitrogen tanks are nothing alike. if you want a nitrous bottle, buy a nitrous bottle meant for you car. i would suggest turbo over nitrous though, had both and still got turbo. the nitrous is fine, but not constant. when the bottle pressure drops, hp drops. it costs about 50 bux to fill a 10lb bottle, and when you want power you cant just step on the gas, you have to open the bottle thats all the way in the trunk and then flip a switch.
Old Nov 20, 2005 | 08:47 PM
NACvicSi's Avatar
Turbo kit build up is in the works. Got intercooler, oil feed, tapped oil pan, and log manifold. Not even done installing the motor yet lol. 10.5:1 c/r on 5 psi should be fun.
Old Nov 21, 2005 | 12:12 AM
abnaasefmb's Avatar
Default Re: (NACvicSi)
its been a while since i have played with co2 but if i remember right the burst discs on the 20oz let go at about 1100 psi. so if any heat heat hit the bottle it would dump 20oz n2o in your car. the cf wraped are made for the temp change either.
Old Nov 21, 2005 | 12:47 AM
crucian's Avatar
Default Re: Paintball tank nitrous? (bluemax189)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bluemax189 &raquo;</TD></TR><TR><TD CLASS="quote">and when you want power you cant just step on the gas, you have to open the bottle thats all the way in the trunk and then flip a switch.</TD></TR></TABLE>
Well not if you have a remote bottle opener which always sticks in the open postition for some reason!!! But it opens the bottle fine.
Old Nov 21, 2005 | 04:11 AM
Cherchez La Ghost's Avatar
A 20oz CO2 bottle will work as an intercooler sprayer but thats about it. The "nitrous" bottles for paintball really wont do you any good. They are filled with compressed air which is like 60% nitrous. If you can make a setup simliar to an auto nitrous kit with the correct jet sizes i think it would work as a dry setup. I dont think a 45ci or 68ci bottle would last very long tho.
Old Nov 21, 2005 | 07:44 AM
abnaasefmb's Avatar
Default Re: Paintball tank nitrous? (Lekz)
Its not nitrous its nitrogen and i think its more like 70%
Old Nov 21, 2005 | 08:57 AM
Dr Pooface's Avatar
Default Re: Paintball tank nitrous? (abnaasefmb)
No reputable shop would ever fill a container not rated for nitrous.
Old Nov 21, 2005 | 09:21 AM
NACvicSi's Avatar
So for a cheap intercooler sprayer the CO2 spraying the intercooler would work just as well?
Old Nov 21, 2005 | 10:59 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by abnaasefmb &raquo;</TD></TR><TR><TD CLASS="quote">Its not nitrous its nitrogen and i think its more like 70%</TD></TR></TABLE>
karmadhi
Mar 12, 2014 08:23 PM
torqueless
Sep 25, 2005 12:54 AM
Almost
Feb 15, 2005 05:45 AM
