p30 pistons, nitrous, okay?
Old May 3, 2004 | 08:00 AM
m R g S r's Avatar
Default p30 pistons, nitrous, okay?
I am currently building a b16 block for turbo, and I picked up another b16 with p30 pistons. So my question, and yea I did search, but I found different answers to which compression ratio these pistons yield. (b16a block, p30 pistons, p72 head, oem head gasket)
It ranged from 10.8 to 11.6. Which is it? Also, I have a dry NOS nitrous kit already installed in my car, can I use the kit with this motor?
I am only using this motor for the summer, until I have enough for my turbo kit, then that;s going in along with the built b16 motor. Any help is appreciated.
Old May 4, 2004 | 04:20 PM
m R g S r's Avatar
Default Re: p30 pistons, nitrous, okay? (m R g S r)
So is it safe, or will it blow as soon as I spray on it? I don't want that to happen
Old May 4, 2004 | 05:30 PM
Drag_Dc2's Avatar
lsvtec with p30 slugs was one effcient *** setup!!! 40-50 single shot of n2o yielded 12.1 @ 110 on pump gas.
The setup was beat on continuously and still lives on with its new owner. If I had teh opportunity to build another setup like this I would deffinetely use the p30 slugs!!!
Eric
Old May 4, 2004 | 05:33 PM
m R g S r's Avatar
Default Re: p30 pistons, nitrous, okay? (DragEg)
What head were you using? And if I'm not mistaken, the b18b block yields a lower compression than the b16.
Old May 5, 2004 | 12:16 PM
Drag_Dc2's Avatar
same head as i specified i was running ls-VTEC - Keep in mind I am from California where the highest pump gas rating we have is 91. In addition I ran a skunk2 program with the n2o and the timing was set at 14 Degrees.
vtechjunkie
Sep 22, 2009 03:41 PM
dc2leftovers
Dec 12, 2007 06:32 AM
KA24DET92
Mar 28, 2007 11:53 AM
calihondategra19
Aug 9, 2004 04:13 PM
G2Crash
Feb 25, 2004 06:55 AM
