Overheating problem
Old Apr 14, 2018 | 03:46 PM
Todallybuilt's Avatar
Default Overheating problem
Today I was driving around and did a few pulls at first then just regular driving and after 10 minutes after doing those pulls I got a CEL. I went home let the car rest for a while then grabbed my laptop so I could datalog and see what CEL it was throwing. After starting the datalog I did one 3rd gear pull and right after I got a CEL 11, according to Hondata the engine was overheating even though the car temp gauge was at its normal setting. Immediately I pulled over and turned the car off for a while, on the way home the CEL came back even though I was driving like a grandma lol. The datalog shows that the car's ECT got to 219 degrees during the 3rd gear pull then went down to 212 degrees.
Here is what I know, I did a compression test on my B20Vtec Turbo on Friday and the compression was 192,195,198,195. Also there is no coolant on the overflow tank. I put a turbo blanket to help reduce the temperature. I will also be wrapping the down pipe to help the temperature as well, also thinking of getting hood risers even though I totally hate the way they look.
I will most likely do a coolant flush and try putting new coolant. What coolant do you guys recommend I use? I appreciate other suggestions that could help me out. I will be doing a long trip since I will be moving to another state and want to make sure I get this problem solved. Thanks guys.
Old Apr 14, 2018 | 07:26 PM
91Honda_gsr's Avatar
Default Re: Overheating problem
where you boosting at all while grandma driving? so the temp gauge didnt move at all? or maybe you didnt notice it?
Old Apr 14, 2018 | 08:07 PM
TheShodan's Avatar
Moderator
1)Put coolant in the overflow bottle. (OEM Honda coolant w/ some Redline water wetter or Toyota "Pink" OEM coolants are best to use) Don't use that Prestone/Supertech/PEAK nonsense.
2) Are you going by the OEM EGT sensor location, or is the Hondata reading coolant temp from somewhere else?
3) What radiator and fans are you using? (Ebay turbo is risky enough. Going with Ebay fans/radiator is really asking for it)
Old Apr 14, 2018 | 08:36 PM
I was not in boost and the temp gauge didn’t move at all.
Old Apr 14, 2018 | 08:43 PM
I am going by oem egt sensor. I’m using a Garrett t3/t4 turbo with skunk2 radiator and go-autoworks 1550cfm slim fan. I just ordered water wetter, I hope it helps.
Old Apr 14, 2018 | 10:29 PM
TheShodan's Avatar
Moderator
You're thinking ECT sensor. There is no OEM EGT /pyrometer sensor. Get water wetter, yes, WITH the coolant I suggested, or even Pentofrost E concentrate
Old Apr 15, 2018 | 06:21 AM
SpiderX1016's Avatar
Make sure the fan(s) is blowing towards the back of the car.
You can try overriding the fan temp in Hondata to turn the fan on sooner.
Otherwise I'd try the coolant + water wetter like said above.
Old Apr 18, 2018 | 06:11 PM
update after draining the old coolant and putting water wetter with distilled water and now the highest temp that hondata has read is 203.8 and that was after doing a bunch of pulls. Now the outside temperature today was cooler than the day that the it overheated, I will try it again once it gets hot again and give you guys an update.
Old Apr 18, 2018 | 07:46 PM
TheShodan's Avatar
Moderator
It'll get much lower once you use some Toyota Pink or OEM Honda coolant.
Old Apr 19, 2018 | 07:25 AM
Awesome, good to know. Thanks for the advice Shodan and everyone else.
Schnitzer
May 11, 2014 05:15 AM
sleepysohc
May 4, 2014 03:59 PM
typeSwarrior
Jun 17, 2009 07:22 AM
harlen
Feb 19, 2008 05:31 PM
