overheating and coolant overflow?
Old Feb 6, 2006 | 03:41 PM
  #26
Got_soy's Avatar
Default Re: overheating and coolant overflow? (mugencivic94)
you could try the cap, my cap went bad and it kept boiling over, but i never had boost when that happened, is the rubber cracked around the cap?
Old Feb 6, 2006 | 03:42 PM
  #27
mugencivic94's Avatar
i havent looked at the rubber wat if it is would it cause this bullshit
Old Feb 6, 2006 | 03:46 PM
  #28
Got_soy's Avatar
Default Re: (mugencivic94)
i could, is there pressure when you take the cap off?
Old Feb 6, 2006 | 03:53 PM
  #29
yea theres some ive never taken a head off while in the car what all do i have to remove and what not?
Old Feb 6, 2006 | 03:58 PM
  #30
Got_soy's Avatar
replace the cap before you do that, and while out, buy a helms/chiltons manual, it will
give you all the torque # and sequences, along. You might be able to download one
from online.
Old Feb 6, 2006 | 03:59 PM
  #31
i got a chilton book does anyone ever run into problems with those small stock radiators
Old Feb 6, 2006 | 04:00 PM
  #32
Got_soy's Avatar
maybe, but check the cap, its not that expensive
Old Feb 6, 2006 | 04:50 PM
  #33
Default Re: (Got_soy)
the rubber on the cap looks fine?
Old Feb 6, 2006 | 05:27 PM
  #34
anyone else
Old Feb 11, 2006 | 07:49 AM
  #35
ok so im really stumped now i changed the hg with a cometic one and got brand new arps and it still overheats but it dont push the coolant no more what else could it be
Old Feb 11, 2006 | 08:21 AM
  #36
igo4bmx's Avatar
same crap is happening to me
once you lift the headgasket you NEED to replace it,. re-torquing won't do anything.
couple things
1- lower timing in boost
2- torque up new headstuds, and then after a couple drives, retorque, even higher than reccomended.
3- also try replacing the radiator cap, just for shiznit and giggles
Old Feb 11, 2006 | 10:03 AM
  #37
coneheadsracing's Avatar
Default Re: (igo4bmx)
Possibly your tune, did you have a shop do it? I ran 15psi on my d, with a small radiator, that was actually loosing all the fins out of it. When i did my first head swap i put too much oil on the bolts, and it seeped inbetween the head and block, so that was bad before i even started it. Put a new one in, NA still, and put a water temp guage for boosting later. I was overheating all summmer. Went boost, and was really pushing out the fluid. Changed it, and no more problems, and no overheating. If you still are over heating after your new headgasket i don't know. Whats your air fuel ratio. Did you replace your thermostat, there cheap. Your water pump might be bad too, they don't like to get overheated, but i doubt thats bad unless its leaking coolant.
Old Feb 11, 2006 | 12:02 PM
  #38
Default Re: (coneheadsracing)
a bad *** shop RLZ in concord NC did the tune and i already changed the thermostat and the headstuds are recomemded being torqued to 60 and i got them at 82 so? i dont know what else it could be the a/f is pretty much at 14.7 i watched when he dyno tuned it
Old Feb 11, 2006 | 12:48 PM
  #39
igo4bmx's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mugencivic94 &raquo;</TD></TR><TR><TD CLASS="quote">a bad *** shop RLZ in concord NC did the tune and i already changed the thermostat and the headstuds are recomemded being torqued to 60 and i got them at 82 so? i dont know what else it could be the a/f is pretty much at 14.7 i watched when he dyno tuned it</TD></TR></TABLE>
what about the timing ?
Old Feb 11, 2006 | 03:02 PM
  #40
dornon13's Avatar
wait...youre at 14.7 in boost or you are overheating out of boost....
Old Feb 16, 2006 | 10:17 PM
  #41
tub_sephiroth's Avatar
Default Re: (dornon13)
Wow! 14.7 in boost. That's hella rich.
Old Feb 17, 2006 | 05:57 AM
  #42
igo4bmx's Avatar
Default Re: (tub_sephiroth)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tub_sephiroth &raquo;</TD></TR><TR><TD CLASS="quote">Wow! 14.7 in boost. That's hella rich.</TD></TR></TABLE>
u mean lean
string
Jan 30, 2007 07:41 PM
zbaber
Oct 22, 2005 11:40 AM
Honda-Hooligan
Nov 21, 2004 12:00 AM
Kelly.
Mar 12, 2004 11:15 PM
